Sportbike knobbies
Discussion in 'Mechanics Garage' started by silverbullet132, Aug 31, 2012.
  1. silverbullet132
    silverbullet132 New Member
    Continental TKC80's, would anyone else put them on their VFR? I enjoy some mild off roading with mine, was looking for some opinions on it.
  2. betarace
    betarace New Member
    Middleburg, VA
    Stop huffing paint
  3. BereaVFR
    BereaVFR New Member
    Berea, KY
    Go for it. Sorta like the Crossrunner. (Do you folks in Canada get the Crossrunner?) The only concern I would have is whether or not the knobs will fit under the front fender. If you do it, report back. I am curious.
  4. silverbullet132
    No crossrunner here. The knobs should fit as the tires have the same size #'s as the vfr currently uses.
    Sent from my MB860 using Tapatalk 2
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Stock tires will do as much off-roading as the VFR is intended to do. Gravel and/or dirt roads are fine. IMO if you going offroad enough to need that kind of traction, you're very likely to drag the belly pan and screw up the fairing bits. JMO of course.
    You can't make a sow's ear out of a silk purse. :biggrin:
  6. silverbullet132
    Last time I took my bike down a gravel road it was fishtailing everywhere (v45 sabre) so I thought these would be a huge improvement.
  7. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I've been on several gravel roads, a couple not by choice, and the VFR has always behaved admirably. I've stayed out of the very deep and loose gravel stuff though.
  8. squirrelman
    Knobby tires on a VFR is wholesale nonsense.
