Stainless Steel brake lines?
Discussion in 'Mechanics Garage' started by azsmp, Mar 21, 2008.
  1. azsmp
    azsmp New Member
    Mesa Arizona
    Anyone made this modification yet? Did it make a noticeable difference? How about cost and reccomended brand. Thx everyone, this is a great site!
  2. douglasthecook
    douglasthecook New Member
    Tucson, AZ
    Last winter I pit on Galfer S/S lines, and wave rotors, and pads. One of the best bang for the buck mods you can do is S/S brake lines. Improves feel a little, as the lines won't swell under pressure like the OEM rubber lines will.
  3. powderrecon
    powderrecon New Member
    Seattle
    My 96 came with them, however from what others have told me..what ^^ said
  4. hondawolf
    hondawolf New Member
    Livermore, Ca
    Has anyone put them on a 6th gen? Did you keep or remove the linked brakes? If keeping the linked brakes, I could see the upgrade being very expensive. I did Galfer s/s lines on my old bike, gave a more responsive brake and feel.
  5. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Probably couldn't cost more than about $500, and wouldn't add more than five pounds...:biggrin:
    Sorry, I couldn't resist! I have never added them myself, but it seems that those who do always like them.
  6. hatzyian
    hatzyian New Member
    Larnaca Cyprus
    I've just finished fitting Hel lines to my 1999, good feel and I really notice the extra power when braking hard.
    Complete set were about 400Euro.
  7. Alaskan
    Alaskan Member
    Alaska
    You 6th Gen owners want to improve braking power and feel? Seems adequate with the stock lines to me . . . .
    My First Generation would definitely benefit from braided lines, though.
  8. mello dude
    Romania
    Speigler Performance should have a kit for you. But my suggestion is before you jump out and spend $400 on brake lines - if you havent done a good brake bleed in 3 years plus, do that first and see if thats a improvement for you. Lots of times people report major improvement from going to the new lines when the improvement is instead the result of a good brake bleed.
    - I'm not knocking the steel lines, but do a good bleed first, then decide if the bucks spent will be worth it.
    MD
  9. Spike
    Spike New Member
    Yes
    yes
    only tried Galfer, so I can't compare to other brands
  10. Spike
    Spike New Member
    Galfer has them for the 6th, got 'em, haven't installed them
    it keeps linked brakes, which makes them a little more of a bear to install, but you just replace the lines, not any of the other braking stuff
  11. Spike
    Spike New Member
    I think less than $500
    and way less than 5lbs, if any at all, the kit just doesn't weigh very much
  12. keeena
    keeena New Member
    MA
    I've heard HEL recommended because they use stainless fittings. Do you buy it, or is it hype?
    HEL Link
    I've used Galfer lines in the past and never had a problem. They do feature a full kit for the ABS VFR.
    I agree w/ Mello - bleed first. I find that theres only a minor improvement w/ SS lines for normal riding...a bit better feel. A larger improvement when coupled w/ other brake upgrades. Absolutely worth the upgrade if factory lines require replacement.
  13. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    I'm with mello on this one. I think the stretch/swell business on any modern bike is bunk. That being said, the quality of the materials in a good SS braid kit can't be beat. I got a custom set made at my local shop out of Earls hose and fittings. They cost about the same as prepared aftermarket bits and they were guaranteed to fit. Sometimes the ready-made stuff will have angles off and require you to do some twisting on the lines, uncool.
  14. Taz
    Taz New Member
    from SoCal, now in Utah
    Well the stretch isn't bunk if you push the bike in the canyons or track day's, especially if you trail brake, because with stock they will get mushy.
    I had Earls fitted to mine as well & was a big improvement that was noticable.
    I latter replaced the master, & the rotors/calipers as well de-linking the bike with a Brembo set up.
    But for the average rider/commuter, the stock brakes are fine, because if they weren't, the bike wouldn't of been sold or re-called by now.
  15. GenLightening
    GenLightening New Member
    Minden, NV
    Quick way to see, grab a brake hose and squeeze the brake lever. When the hose moves or gets bigger you've just proved it. Pretty much a guarantee that it does on any vehicle with rubber hoses.
  16. NYMBYSS
    NYMBYSS New Member
    spiegler brake line have great fit and finish even custom lines if you need them all you have to do is give them lengths and the fittings you need,great product.
  17. Somefun
    Somefun New Member
    Orange, CT.
    Guy's I got the Galfer kit and I'm in trying to do the install but the kit comes with two rear lines and one works but the other doesn't? One line is hose and on the end is a square block and out of that block comes a steel line that goes in to some kind of distribution block. But the line they gave me has the end on it that you put the bolt through. Anyone seen this issue?
  18. Keager
    Keager Member
    with the 6th gen having the linked brakes, there are so many points that need to be bled out. SEVERAL people around here (shop, honda shop, Honda Certifed Tech - friend) said not to just because of all the locations.
  19. Somefun
    Somefun New Member
    Orange, CT.
    The Galfer lines won't fit on a 6th gen non ABS. I found out the hard way... But I installed the Galfer wave rotots front and rear along with EBC HH pads front and rear. Flushed the fluid and now she will stop like a MOFO!!!!
