starter issue
Discussion in '3rd & 4th Generation 1990-1997' started by 83interceptor, Jun 26, 2014.
  1. 83interceptor
    83interceptor New Member
    jacksonville,il
    every so often when i go to start the bike i hit the button it starts to crank then just locks up if i rock it or bang on the side by the starter some times it will work other times if i keep hitting the button it will finally crank again
    most of the time it cranks and starts right up
    1992 vfr750 91,000 miles on original engine and rectifier as far as i can tell
  2. kennybobby
    kennybobby New Member
    What do you measure as the battery voltage at rest, with the key on, and when pressing the starter button?
  3. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Yep.. Sounds like you're not getting enough power to the starter to crank it over under compression. This could be that your battery doesn't have enough juice to crank it over or that you've got a loose wire somewhere, namely a battery terminal. Check the voltage like kenny suggests. If it is low, charge it up and have it tested. If it tests good, it is time to look for loose connections and maybe charging issues.
  4. 83interceptor
    jacksonville,il
    just checked it when starting before start 12.89 during start dropped to 11.01 it started and jumped to 12.9 at idle then ramped up to 13.35 while running
  5. ridervfr
    Belgium
    you need to re-build your starter motor, its easy and worth it. I used to have a "hot start" issue and thats what it was. Now the bike sounds like the ones that come off the showroom floor with a whirl to life, sorry, can't put a sound clip in :lol:
  6. ridervfr
    Belgium
    get one of these for your bike
    http://roadstercycle.com/index.htm
    91,000 is an accomplishment, my 91 has almost 80,000 but I won't bore you with the parts/time/labour/money that went into it. I love it, what can I say. I am a shallow bastard. :loco:
  7. 83interceptor
    jacksonville,il
    well it wouldnt start for me this morning pulled the seat and checked the battery after multiple attempts to start battery was showing 11.01 volts with my meter checked it when hitting the starter button dropped to 2.98 volts i put my trickle charger on it to see if it will come back questioning if the rectifier finally failed on me yesterday ive got a new one ordered but not sure when it will show up
  8. 83interceptor
    jacksonville,il
    tried it at lunch battery was back up to 12.89 went to start it. it started to crank over then it locked up and will not turn over looks like ill be pulling the starter tonight to test it if that tests good i think ill have to pull the starter clutch
  9. kennybobby
    Your battery is no good. The extreme voltage sag under load is the clue. A trickle charger cannot charge a battery, only float it once it is already full. There is likely no problem with the starter, but you will never know while using a clapped-out battery.
  10. squirrelman
    Maybe a cracked starter clutch housing if it's locking up ??
  11. ridervfr
    Belgium
    Do we know how many miles are on the "sed-bike?" Batteries are often over looked as other people said, they are very mysterious, much like "Mushi" is. Thats German for poosey btw :stripper7: :pound: :loco:
  12. ridervfr
    Belgium
    Strike that, he said 91,000 miles, my bad. :thumbsup: :vtr2: Hi-Ice-Hunchin :wave:
    Start
  13. 83interceptor
    jacksonville,il
    tried it by jumping it off a car battery got alot of growling and weird rattleing noises from engine so pulled the starter off and apart found one brush really worn starting to worry it might be the starter clutch i ordered a starter rebuild kit to fix the bad brush
  14. ridervfr
    Belgium
    I feel I can do this: "I told you so." You know the honda parts catalog makes you buy the parts to the starter sprag clutch seprately. So, you need the body, three springs, three caps, three of these weighted cap things (which I don't know the name of.) Anyway, if it were a Kawasaki, you could get the entire kit for one price instead of having to be an accountant.
  15. ridervfr
    Belgium
    oh, and dont forget the clutch gasket if you do the starter sprag. Keep track of them fibre washers on your starter motor as they have a sequence too :mech:
  16. 83interceptor
    jacksonville,il
    pulled the clutch cover off found starter clutch cracked in two spots any recommendations where to get new one
  17. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    I have a very good used one I bought for mine when I had it. $40 (what I paid) it's yours + $6 shipping USPS little box.
  18. 83interceptor
    jacksonville,il
    how do you want me to pay for it
  19. GreyVF750F
    GreyVF750F Member
    paypal is fine pm me
  20. 83interceptor
    jacksonville,il
    pm sent thanks
