Starter problem 4th gen
Discussion in 'Mechanics Garage' started by dxhall, Apr 18, 2022.
  1. dxhall
    dxhall New Member
    Battery is fully charged. Starter engages for a second, then disengages and just spins. Don’t see any bad or corroded connections. Thoughts? Just buy a new starter?
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    Starter clutch likely not engaging properly.... a little refurb might fix you right up.
  3. squirrelman
    ^^ yes, the starter clutch needs inspection/service.
  4. Terry Smith
    New Zealand
    The starter clutch has some heavy rollers that throw out and disengage when spun fast by the engine, but lock down and grip when driven by the starter, held in place by springs. If the springs have gone limp or the rollers are worn, then the clutch won't grip and the starter will just spin. The starter clutch is easy enough to rebuild, I bought a kit for my 86 which had rollers and springs, but you do need a crankcase gasket as well. If you don't fancy renewing the engine oil, you can do the job on the side stand without oil loss (but don't drop any old gasket or parts into the sump!).
    The starter clutch is the big disc next to the clutch, driven from the train of gears at the lower right where the starter motor is. The three bolts hold it together, and there is one bolt (removed here) holding it onto the splines on the crankshaft. IMG_2539.JPG
  5. dxhall
    dxhall New Member
    What’s the best source of parts for a rebuild like this?
  6. Terry Smith
    New Zealand
  7. raYzerman
    raYzerman Member
    Millgrove, ON
  8. ridervfr
    Belgium
    My Kawasaki EX500 has the typical "crash" sound sometimes when I hit the starter, its only when the starter engages, I have swapped out two starter sprags on these bikes and still get an occasional sound.
    The VFR can crack the metal assembly sometimes, I have changed one on one of my gen3 bikes just because I had the parts and it did'nt cost me anything. What I did run into regarding starting was with my high mileage gen3 bike when it was hot. I had a starter lag, I ended up buying an overhaul kit with the brushes etc and that cured my hot start problems. Sounds like a new bike now too.
  9. dxhall
    dxhall New Member
    Thanks for all of the help. I got it apart today, and the problem is a cracked starter clutch. The other parts look ok. Is it best practice to replace the rollers and springs when it’s apart?
    ridervfr likes this.
  10. squirrelman
    rollers only if you see damage, springs yes as they cost almost nothing.
  11. dxhall
    dxhall New Member
    Bad news on the starter clutch. Back ordered everywhere until late May. Anyone have any lines on a used one? There’s nothing on eBay.
  12. squirrelman
    alot of back orders turn bad, so i'd suggest trying to find one from a salvage yard as the part you need is very hard to find new. 30+ year old bikes are like that.
