starter solenoid
Discussion in '1st & 2nd Generation 1983-1989' started by Grade247, Aug 11, 2012.
  1. Grade247
    Grade247 New Member
    so today I got my knockoff after market solenoid was TRYING temember how the 4 wires were plugged into the 4 pin connectors and reconnected the battery only to have smoke come out of the solenoid (idiot) does anyone have a picture I can see of how the wires are plugged into the solenoid. another prob i noticed is when did I that something burnt out? when that happened my battery has 12 volts reading off it BUT when I key on I am getting 0 power no lights or anything
  2. Grade247
    Grade247 New Member
    can anyone help me out I think it is more then the starter solenoid causing issues. my initial issue was my bike refused to start period unless I pop started it but afterwards would run fine no issues. I took the starter off and thank god the bearing was spinning in the case not as it should roll freely so that is being looked at. Now to the most current issue I found how to hook up the starter solenoid but now each time I hook it up I instantly blow fuses can someone help me please
  3. Dukiedook
    Dukiedook New Member
    Kansas City, USA
    How do you know your original solenoid was bad?
  4. squirrelman
    You might have mistakenly switched positions of main harness wires that go to the fuse panel with the 2 wires (one is ground) that send power to close the starter motor contacts.
    Study your wiring diagram.
  5. Grade247
    Grade247 New Member
    I have everything sorted out the R/R shorted out. the solenoid was bad also tested it before buying a new one. I am currently sourcing a R/R right now for a decent price and plugging the 4 wires that go to the solenoid incorrectly shorted out my clutch diode but should have the parts in soon. thank you all
