Starter Switch - Remove and Replace??
Discussion in 'Mechanics Garage' started by Can Cutter, Jan 4, 2016.
  1. Knight
    Knight New Member
    USA
    There's hondapartshouse.com and partzilla for new ones, if they have it. Good luck and let us know how this goes!
  2. Badbilly
    All the advice aboot bikes other than this guy's 1985 VFR were probably well received too.
    Maybe cable slack could have been accomplished by unbolting the bars?
  3. NormK
    NormK New Member
  4. Allyance
    Allyance Insider
    Germany
    East Bay, California
    I double checked partzilla for my 83 and your 85, doesn't show a separate switch available inside right hand assembly, only the complete assembly. What did you find? Are contacts salvageable?
  5. NormK
    NormK New Member
  6. Can Cutter
    Can Cutter New Member
    Contacts are not able to be salvaged. Melted contacts and plastic. I need the whole assembly.
  7. Can Cutter
    And the good news is that I found a starter switch at 5thgearparts.com. Correct part number and all.
  8. Allyance
    Allyance Insider
    Germany
    That should last you another 30 years!
  9. Can Cutter
    One can only hope!
  10. Can Cutter
    The switch is installed and the bike is running great. 5thgearparts.com was a pleasure to work with.
