stator ?s
Discussion in 'General VFR Discussions' started by volmann, Mar 18, 2016.
  1. bigbadbass
    bigbadbass New Member
    NEW YORK
    you do need to make a good connection between meter probes and wires. Some meters use alligator clips to attain that good connection. VERIFY.
    WHILE bike idling and meter set to AC volt setting.
    want to post a pic of your meter? Digital?
  2. volmann
    volmann New Member
    Johnson City TN
    Ok..i had meter set wrong
    Now i get low 20s at idle and this at 3000 rpm or so
  3. bigbadbass
    NEW YORK
    on all 3 legs?
  4. volmann
    volmann New Member
    Johnson City TN
    Yes all 3
  5. bigbadbass
    NEW YORK
    i'd move on to regulator output, set meter on <20 DC volts
  6. volmann
    volmann New Member
    Johnson City TN
    Test at the green red wire coming out of r/r
  7. bigbadbass
    NEW YORK
    unplug, use meter probes direct to regulator outputs
    you did post in this thread all your reg terminals were able to be unplugged, correct?
  8. volmann
    volmann New Member
    Johnson City TN
    11.4 coming out of r/r at idle
    Doesn't go up with rpms stays at 11.4
  9. bigbadbass
    NEW YORK
    suggestion #1....trash your RR, get a Shindengen Mosfet type.
    suggestion #2 ...change your username to VOLTMAN!
  10. skimad4x4
    France
    French Alps & London
    OK so your RR output is 11.4 volts - which means its only fit for the bin.
    So head over to Roadstercycle - http://www.roadstercycle.com/ and get a decent replacement!
    Take care.
    SkiMad
  11. volmann
    volmann New Member
    Johnson City TN
    *The Super Mosfet Kit FH020AA
  12. V4toTour
    V4toTour New Member
    Just keep in mind, a stator failure soon following the toasting of a bad R/R isn't uncommon. Those hot wires you felt was excess current, meaning extra strain on your stator coil. I replaced a bad R/R, only to have the stator fail like a thousand miles later. You might want to purchase as spare stator coil to have handy as well.
  13. volmann
    volmann New Member
    Johnson City TN
    What about a R1 rectifier?
  14. V4toTour
    V4toTour New Member
    a gsxr one might work, a ninja one might work. The R1 regulator may very well be the FH020AA. I have no idea what revision or styles those bikes use. You're over thinking this, go order the one from roadstercycle and call it a day. :frusty:
  15. bigbadbass
    NEW YORK
    as long as you can wire it correctly, thats fine.
    I'm running an old Kaw ZX10 mosfet, Shindengen model FH010BA, going into my 7th trouble free season.
    So successful, I put same on my 900SS a year later. both remain trouble free.
  16. volmann
    volmann New Member
    Johnson City TN
  17. bigbadbass
    NEW YORK
    beware here...that may be a far east knock off ...original Shindegan ZX10 in that vintage are clearly marked FH010BA. Search ebay motors under FH010...look at pics....clearly marked.
  18. volmann
    volmann New Member
    Johnson City TN
    Got the R1 rectifier instaled yesterday works great
    Its showing 14.2 volts while riding and 13 at idle
    With the old rectifier it never got above 13.4 while riding and 12.5 at idle
  19. bigbadbass
    NEW YORK
    R1 Shindengen Mosfet good choice, voltman
  20. volmann
    volmann New Member
    Johnson City TN
    Got one from a motorcycle salvage yard came off bike with 3700 miles on it
