Stator Test?
Discussion in 'Mechanics Garage' started by PHQNMVN, Aug 19, 2009.
  1. PHQNMVN
    PHQNMVN New Member
    vancouver,wash
    Is there a way to test a stator with a multi meter? If so how?
    each yellow wire should show continuity with others.
    yellows should show No continuity to ground
    with engine running and stator disconnected from R/R between idle and 7000rpm,output between any 2 wires should be between about 8 to 60 AC volts depending upon rpm
  3. crustyrider
    crustyrider New Member
    North Country, New York
    mine showed 4volts at any RPM... good thing I am replacing it
  4. PHQNMVN
    PHQNMVN New Member
    vancouver,wash
    thanks guys better get to testing
  5. squirrelman
    There's the "smell test" too, cuz a burned stator has a distinct, skunky odour.....
