still having problems !!!!! need petcock to
Discussion in '1st & 2nd Generation 1983-1989' started by thermostate, Jun 21, 2009.
  1. thermostate
    thermostate New Member
    jacksonville,fl
    about two weeks ago when I bought it!
    At that time......did you actually ride the bike and shift through the gears??
    could the same problem have been there and you didn't notice??
  3. thermostate
    jacksonville,fl
    no I test rode it when I bought it and when I got home I drove it alittle bit and thats when it happened lucky it was in my drive way!
  4. soundmaster31
    soundmaster31 New Member
    Jackson, Michigan
    So you said you already replaced the clutch fluid? Did you bleed it properly? AT the bleed screw on the bottom and sometimes you need to crack the banjo bolt open at the top of the system cause air bubbles get trapped up there OFTEN.
    Make sure the system is 100% air free. Then look into rebuilding the cylinders like squirrel said. He's not all bad.:wink:
  5. squirrelman
    check to be sure all the bolts holding the sprocket cover to engine are tight and also the bolts holding slave cylinder to that cover.....
  6. soundmaster31
    Jackson, Michigan
    Good call squirrelman. If you had that cover off and pressed the clutch, it can force the wall of slave cylinder away from the cover causing leaks or air...well at least on my 5th gen.
  7. TRX250R
    TRX250R New Member
    R.I.
  8. volks6000
    volks6000 New Member
    Jacksonville , Florida
