Stock mirrors floppy..
Discussion in '6th Generation 2002-2013' started by APSengineer, Feb 28, 2014.
  1. APSengineer
    APSengineer New Member
    Is there any way of tightening the pivot that the glass bit attaches to?
    I've only gotta fart in the general direction of one of mine and it's pointing at some random place!
    Cheers.
  2. Allyance
    Allyance Insider
    East Bay, California
    Save your gas, there is a little plastic button you pop out to access hex bolt. Caution don't over tighten so mirrors won't move when bumped hard or if bike decides lie down and sleep.
  3. APSengineer
    Cheers Allyance. Didn't make my self clear - the head part containing the glass. There's a ball type joint - one of mine is a bit loose.
  4. Allyance
    Allyance Insider
    Maybe there is someone else that has had this problem.
    One idea is to take some contact cement (rubber cement), apply small around ball joint and swivel mirror to get some cement under mirror part, adjust mirror to desired position, and let dry. Take some lighter fluid (benzene) and clean up excess cement on outside.
    Went and looked at mine, I think a couple drops of Lock Tight might work better.
  5. Fantastic!
    Fantastic! New Member
    These things are disposable so chances are you are looking at $88.36 for a new Honda part :(
  6. rangemaster
    rangemaster New Member
    Albuquerque, New Mexico
    Or about half that for one of the EMGO ones.
  7. Allyance
    Allyance Insider
    Couple of drops of locktite is a lot cheaper, worth a try till you get replacement.
  8. VFR Love
    VFR Love New Member
    New York
    eBay has knock offs for cheap. Glass quality is the same as OEM.
    You could try heating the plastic with a heat gun and popping out the mirror. Another forum member did it to add a display under the mirror glass.
    Don't know if you'll find anything inside that ain't outside of course!
    Or a small screw parallel with the ground. You will still be able to pivot up and down a touch but fore/aft will be adjustable via the mirror arm itself.
  9. Badbilly
    Lighter fluid is mostly naptha and can contain up to 1% benzene as opposed to benzine.
    The better solvent for contact cement is toluene.
    Some of the Loctite products contain shellac dissolvable in alcohol or nitrocellulose lacquer dissolvable in acetone or common lacquer thinner. LockTite is sort of like Bondo .Many different types for different uses.
  10. Allyance
    Allyance Insider
    You are right, many years ago I think it was more benzene, you can Google the MSDS on any chemical. I keep a can of Zippo lighter Fluid around for getting labels off and cleaning up contact cement, comes in small can, easy to dispense.
    Best way to remove bumper stickers and other labels is with hair dryer, by heating up label/sticker to maker adhesive pliable, then clean up residual with solvent of choice.
    My mirrors are pretty stiff due what looks like mineral deposits, just thought he could do same with common materials.
  11. VFR Love
    VFR Love New Member
    New York
    Maybe a good scuffing with a coarse strip of sandpaper? Just note the area hidden when in proper position for riding, bend it to expose that surface and scuff away.
    Maybe a Dremel tool could create the right scuffs or a razor heated with a lighter to melt and expand the hash marks?
    If nothing else it's more "bite" for your epoxy of choice.
  12. REEK
    REEK New Member
    Sacramento CA
    If you end up buying a new mirror, you might consider some knock offs. I bought a genuine Honda replacement last year for my 07. When I got it, it had all the appropriate markings but unlike the non-broken side, now made in Taiwan and the optics were piss poor compared to the original OEMs. I'd imagine the knock off quality of optics atleast, would be similar.
    Not sure why this would be, maybe Honda has several sources and I just had a bad draw.
  13. APSengineer
    Thanks for all the chemical warfare suggestions!
    I'll don' my lab coat and breathing gear and have a go later. If there's reports on the news about a chemical explosion in a small town in the UK later - you know I've made a bad choice!!
    I'm sure there's a little 10mm nut that needs nipping up laughing at me behind the glass!
    Cheers
    Rob.
  14. Allyance
    Allyance Insider
    Maybe somebody's got damaged mirror they can remove glass and let you know!
