stop sliding on drivers seat ?
Discussion in 'Mechanics Garage' started by panman, Nov 20, 2009.
  1. panman
    panman New Member
    Bristol, England
    I have started wearing my winter textile trousers and I keep sliding all over my drivers seat, any tips on best material to put on seat as a temporary measure till I start wearing my leathers again.
    cheers
  2. derstuka
    San Diego, CA
    Do you have the stock seat, or aftermarket? If stock, I highly recommend a "Sargent" seat. Lots better comfort than stock, looks better, and it has a sort of wedge behind your arse that helps keep you from sliding off performing a superman...lol.
    Textile pants do tend to slid around a tad more than jeans and leathers do...IMO
  3. panman
    panman New Member
    Bristol, England
    I have a stock seat and might go for a seargent in the long run, but am short of the readies at the moment and would like a quick fix over the winter.
  4. 34468 Randy
    Duct tape. Or crazy glue. Yup, I notice the same thing but it doesn't seem to bother me. Cept when I pour on the coals and fall off the back. I keep saying I am going to get a Sergent or a Corbin but it has been over three years now and going into my 4th season of winter drivng. The stallion is going to be plum worn out before I get around to getting the seat.
    I can't think of anything that you could apply to your seat that would not Fug things up and make a mess. You might try stretching some cloth of some sort tight over the seat but I think that would look rather tackey.
  5. safetypro10
    safetypro10 New Member
    Dallas, TX
    Easy way, lift up the vinyl, take an electric carving knife and cut the foam so it forms a little scoop towards the rear seat. Reinstall vinyl and pull tight, instant non-slip now with a little step at the rear seat.
    Go here to learn how: DIYMotorcycleSeat.com - Home Page
    Larry
  6. mrich12000
    mrich12000 New Member
    Calgary, Alberta.Canada
    Vecro your but.:eek:
    :worthless::behindsofa:
  7. crustyrider
    crustyrider New Member
    North Country, New York
    I would suggest sewing a patch of denim...of maybe suede leather across your bum..... if that don't work...velcro
  8. heymike
    heymike New Member
    Edmonds, Washington
    Just a thought. Those little pads they sell to hold your cell phone to the dashboard really grab. One of those on the seat might be enough to keep you in place.
  9. 34468 Randy
    At a stationary Supply Store look for a clear desk matt that has a piece of rubber beneath the clear plastic. You know, for keeping pitures and the such in place under the matt. Put this on your seat and staple to the underside of the saddle. Think maybe?
  10. Gears
    Gears New Member
    Western PA
    My Sargent seat is much slicker than my stock seat was.
    Maybe try griping your tank with your knees.
  11. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    The quickest and easiest non-damaging fix is to buy some of the tacky rubber material that is used under area rugs to keep them from moving around. You should be able to find it at most home stores. Just cut it down to size and lay over your seat and you should be good to go!!
    Regards,
    Rollin
  12. Ozwanderer
    Ozwanderer New Member
    Coffs Harbour, NSW
    Hi chaps
    I scored a fitted sheepskin seatcover... a bit of stretching and grunting to get it on, and it ties in 3 places across under the seat.
    Fixed the slippery issue nicely....
    ... and nice and cushy on the tender bits
    ... AND no more burning bum if you park in the Aussie sunshine.. :biggrin:
    Cheers
  13. jay956
    jay956 New Member
    Richmond, Virginia, United States
    the problem isnt you seat. grip the tank with your knees.
  14. panman
    panman New Member
    Bristol, England
    I eventually bought an oxford rubber blanket which we use in England to throw over the back and sides of your bike to stop throwover panniers rubbing on the paintwork.
    I cut a small piece to fit over my seat and superglued it undereach side and it works a treat.
  15. k1c
    k1c New Member
    Northern New York
    The company that makes Thermarest camping mattresses also supplies a spray on grip to stop one sliding off the mattress in the throws of, well, active camping!
    Works a treat and is invisible.
  16. Mac
    Mac New Member
    NC High Country
  17. Nungboy
    Nungboy New Member
    Tucson, AZ
    All good ideas, folks! I LOVE this Forum (such helpful chaps)!
    Just be glad you are not on a Kawasaki Z750S...that stock seat was tilted down towards the tank so EVERY slight deceleration made me crunch against the tank. Thank goodness I wrecked that bike before it wrecked me!
  18. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    I have the same problem on my 6th gen, with a seargent seat. Stomp grips are on the list of goodies to buy next.
    Stomp Design Online | HONDA
  19. Nungboy
    Nungboy New Member
    Tucson, AZ
    The TechSpec products are the best. Ihave them on both bikes now. It helps alot (as long as you squeeze those knees)!
  20. skimad4x4
    French Alps & London
    One of these might help.
    Triboseat Rider
    Skimad4x4
    6th Gen Militia #218
