stuck odometer
Discussion in '1st & 2nd Generation 1983-1989' started by schrocketeer, Jun 19, 2020.
  1. schrocketeer
    schrocketeer New Member
    North Alabama
    Would you please help me with any tips for reassembling a speedometer/odometer/tripmeter?
    I've put a light amount of 3-in-1 oil on all of the gears and shafts. I'll check gaskets/seals on re-assembly, to keep water out.
    The odometer on mine has been stuck since I bought it about 5 weeks ago. I suspect the corrosion on the odometer shaft, which you can see right above the trip-meter shaft.
    There was a spare on ebay, so I bought it, thinking I could assemble one working unit from the two.
  2. Diving Pete
    Diving Pete Insider
    its usually the cable that has the problems... all my speedo issues have been caused by them..
    schrocketeer likes this.
  3. schrocketeer
    North Alabama
    Thanks for the cable reminder. I forgot to say I checked the cable. It's not broken. It spins freely.
  4. Diving Pete
    Diving Pete Insider
    Put the cable into the speedo, connect other end in a Drill, spin it up, does the speedo move?
