Super Charger
Discussion in '6th Generation 2002-2013' started by TOE CUTTER, Jul 18, 2011.
  1. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    I saw it, just didn't have a good response formulated, freeeeeeekin Troll fail......................
  2. TOE CUTTER
    Did I get thread jacked again?
  3. crustyrider
    crustyrider New Member
    North Country, New York
    yeah...I think your Super charger thread is turning into a superchargercrappyclutchE3Echoisatroll thread..or more simply put..... Tiger Tiger.....
  4. Alaskan
    Alaskan Member
    Alaska
    I am planning to repaint my 2004 Italian Red VFR in a high-gloss Italian Red color . . . only better than stock.
    You know what I mean?
  5. ignoreance
    ignoreance New Member
    Santa Clarita
    Never learned to play but I can play it for you :violin:
  6. Badbilly
    Could you hum a few millibars?
  7. Metallican525
    Rockville, Maryland
    Shit, sorry Toe :focus:
  8. slowbird
    slowbird Member
    Toronto, Ontario.
    Gravy is the most important food at Thanksgiving
  9. Alaskan
    Alaskan Member
    Alaska
    Cut through the threadjacks and keep us informed. The clutch mod sounds interesting - and unique. You are our VFR Petri dish, growing the rare VFR culture.
  10. stoshmonster
    stoshmonster New Member
    Everything tastes better with ketchup I say.
    Sorry TOE,couldn't help it.:redface:
  11. TOE CUTTER
    The clutch parts showed up yesterday and the thinner frictions were not correct, 12 finger instead of 10 finger. So I tossed the OEM clutch back in with the 99lb springs so I could ride this weekend and will figure the Barnett crap oot later.
  12. ridervfr
    hope thats not what it is CRAP.
  13. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    You may find that's all you need is more pressure on the clutch. I was going to suggest before to shim your stock springs and see what happens. You already ordered the current stuff before I could. you could also shim the clutch pack .005-.012" or what ever. There are shims that big and you may be able to find them from some of the equipment you work on.?? Or someplace like Applied Technologies(old Bearings Inc) or the alike.
    I've found the stock clutch seems better over all than the Barnett from the ones I've installed. Most likely just my preference.
  14. tinkerinWstuff
    I don't think shimming a slipping clutch would work. Shims don't change the spring "rate" and could limit the travel of the disks in the basket because the springs would reach full compression sooner.
  15. GreyVF750F
    GreyVF750F Member
    Yes shims will change the pressure/rate. When you change the installed height your applied pressure will change. Same thing you do for valve springs. There is a tolerance there. Plus they are not designed to be used under full compression. That's called coil bind and it does bad things.
    Example, these numbers are made up. A spring that applies 100# pressure at 1" installed height and 150# at working compressed height. Shim it .030 and it now applies 110# installed and 160# at compressed. As long as there is no coil bind.
    There is a maximum the spring is rated for. Actually it's a range and you can't exceed that with out coil bind. The spring is still rated the same. It's just the pressure it's appling can change to a certain point.
    As far as shimming the basket it would have to be checked so what your saying doesn't happen. IF there is to much play (travel) a couple of thou might make it better. Fine tuning makes a big difference sometimes.
  16. Badbilly
    Then we agree that size does count? ;)
  17. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    I'm no clutch expert; but Grey's explanation makes mechanical sense to me.
    Not that that means anything :cool:
  18. Badbilly
    Since a clutch is also the way that oysters propogate. there may be more meaning there than is realized.
  19. TOE CUTTER
    Barnett
    Well as it turns oot the two friction disc's that were incorrect were pulled wrong by one number and Barnett sent the correct ones and I got them today free of charge. An A+ on customer service, the folks at Barnett did not bat an eye at making it correct. :thumb:
  20. TOE CUTTER
    What I ran with
    I decided to run the stock clutch for the time being and installed the 99lb springs with the steels roughed up with a glass bead blasting. I know it will cause premature wear but was looking to ride with this problem behind me. The grip is quite arresting and the pull on the lever is severe but WOW it does hook up and have another in reserve. Will post up when I install the Barnett and let ya'll know how the extra plate set up functions.
