Super Charger
Discussion in '6th Generation 2002-2013' started by TOE CUTTER, Jul 18, 2011.
  1. reg71
    Sikeston, MO
    I have 2 gopros so I can shoot forward and back as he passes me like I'm not moving...
    #41
  2. reg71
    Sikeston, MO
    ok, we are ready...
    seriously . . . . .
    hello!...
    we're ready...
    go
    #42
  3. invisible cities
    invisible cities New Member
    new york
    The requirement of having two cans of WD-40 on hand, make this kit, IMO, ;-)
    Good luck with the install! Looking forward to seeing how this comes together.
    #43
  4. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    :banana::xxx::pop2::pop2::pop2:
    Let's get this show on the road!!!
    #44
  5. Scubalong
    :pop2::pop2::pop2: Humm....intresting
    Toe said I can have the first test run........
    #45
  6. fredsncoma
    That Toe is a ho:stripper:, he told me I had first test ride!
    #46
  7. Gimpy
    Gimpy New Member
    Kansas
    Been looking at one of there kits myself for some time now. I keep putting it off. But I know sooner or later i will end up doing it.
    Let's see some more pics and a video or 2 would be nice as well.
    #47
  8. TOE CUTTER
    So I started oot tonight by taking all the plastic off , other repairs and mods to be done while this is going on.
    [/URL]
    #48
  9. TOE CUTTER
    Yes I am going to do my best to follow the instructions but I do not care for the way they are written. The first portion is to remove all that is to be removed. I would and am going to work by system, and not get too spread oot with no focus.
    [/URL]
    #49
  10. tinkerinWstuff
    That's it?
    Less Coors, more work!:xxx:
    #50
  11. TOE CUTTER
    For the most part it is mundane stuff like remove and install or just remove miscellaneous parts like this spacer nut.....removed a normal nut and installed this. I know, yawn.
    [/URL]
    #51
  12. TOE CUTTER
    You just calm the fuck down Mr. Man! :hss:
    #52
  13. TOE CUTTER
    Got it ripped down to the point that stuff has to be added now.
    [/URL]
    #53
  14. TOE CUTTER
    I did skip a step or two like radiator removal, sensor vacuum hose mod's and opening a beer or two. Pretty sure ya'll do not need to see all that crap. A couple of things did take a second look or two but pretty simple. Air box is idiot proof, even for me. I did only secure the top with two screw's as I do have a premonition it may be coming back off before I am done. The adapters, stacks and base plate are secure though.
    [/URL]
    #54
  15. TOE CUTTER
    To this point I have done my best to do as instructed but I am thinking I will route my wiring and hoses as I see fit for this install. No offense to Dan but it is not my first rodeo with silly shit like this and will take responsibility for my own bikes well being on thing's like that. Now for the bad news.
    #55
  16. TOE CUTTER
    The bad news
    Well it all came to a halt when I realized the ootlet for the super charger is clocked sixty degrees oot. No sugar coating it and no way oot of it.It is supposed to be parallel with the top banjo bolt that is the oil ootlet and not the oil inlet bolt. Points directly into the steering head portion of the frame. So I need to call Dan in the morning to see if he has an issue with me taking it apart to relocate the ootlet in the correct position. Will update Wednesday. Not a big problem as the gen 5 radiator,clutch plates and other parts have not arrived yet.
    [/URL]
    [/URL]
    #56
  17. TOE CUTTER
    If you look closely in the back round photo you can see how far off it really is.
    #57
  18. TOE CUTTER
    Just got off the phone with Dan and he was already aware of the problem and told me it would be fine if I clocked the housing myself. So back to it after work. Really happy he did not want me to send it back. :thumbsup:
    #58
  19. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Thanks for the updates. Taking time to post up pictures is very cool. :cool:
    #59
  20. fredsncoma
    I should be passing through town on Saturday or Sunday. Should I expect my spare set of keys to be ready by then???:smiliehump:
    #60
