Super Charger
Discussion in '6th Generation 2002-2013' started by TOE CUTTER, Jul 18, 2011.
  1. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    This is good. Keep the pics coming with narratives. By the way did the dogs bow out of helping? I don't see any paws in the pics. Or is it your demeanor keeping them away?
    #61
  2. tmyoungjr
    tmyoungjr New Member
    Rochester, New York, United States
    This is great Toe!
    #62
  3. Scubalong
    Not so fast Mr. fredsncoma, Toe told me I have the first test run..........lol
    BTW Thanks for sharing Toe, I cannot wait
    #63
  4. TOE CUTTER
    No they love to help......must keep a constant eye on the young ones. The blondie will walk off with tools and parts and the blackie will chew on wiring and fenders if left unchecked for one second.
    #64
  5. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    Damn toe im feeling all giggty watching this.
    #65
  6. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    That airbox is quite possibly the sexiest part of the whole kit, tis a shame it's all covered up by the tank!! Keep it up Toe, you'll be pullin wheelies all this weekend!! :thumbsup:
    #66
  7. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Great photos and commentary. Keep up the good work. Cant wait to see and hear it...
    #67
  8. TOE CUTTER
    No.....I wish.....Steve Miller Band this weekend in Tahoe......planned way in advance......like Moto GP.........killing me. Worse things to suffer from though.
    #68
  9. TOE CUTTER
    The fix is in
    Talked to Dan this morning and he told me it was OK to spin the housing......Was a bit concerned aboot just doing it withoot talking to him for several reasons including the warranty. The six bolts that hold this thing together were not just to be willie nillie whooped oot with oot a question or ten given it has a 13 to 1 gear ratio from input to ootput. Yes boys and girls.....13 to 1 ratio......this thing is SINGING at full tilt boogie. I know now that there are another set of smaller bolts that retain the gear box together as a unit when the ends are serviced. Here it is clocked correctly.
    [/URL]
    #69
  10. TOE CUTTER
    Much better
    Did a test fit as it was soooooooooo not going to work before and there is quite a bit of things that need to find a new home for this to go in....but it does go in quite nicely.
    [/URL]
    #70
  11. TOE CUTTER
    Installed
    Have to remove the OEM harness holder and relocate the main harness a few inches closer to the front of the frame for the final install. Not that happy aboot that but after talking to Dan this morning aboot my concerns he assured me there was more than enough slack in the harness to pull it off....and he was correct....not a problem at all but I will have to address the issue of wiring once this is fully installed. I am not at all willing to let it go as is and will spend some time with the the repower crew at work to gather some protection for the wiring and extend some of the leads for long term wear. P clamps and zip ties will abound before it is all set and done. But it is installed.
    [/URL]
    [/URL]
    #71
  12. TOE CUTTER
    Yes I am aware how filthy this bike is. I will unfuck that during this post.
    #72
  13. TOE CUTTER
    Plumbing
    Connected the pipes from the charger to the manifold. It did state in the instructions that you would rather be raped in prison than perform this task, and the instructions were correct. Had to fit, refit,fit again,curse,have a beer, curse,curse,have another beer and then call it good. Thought I took more pictures but I was focused and moving like a high dollar hooker at this point.
    [/URL]
    [/URL]
    #73
  14. TOE CUTTER
    Parts
    Still waiting on the radiator , grill, and clutch parts from my uncle Ron. (Ron Ayres). So I went ahead and installed the tension pulley assembly.
    [/URL]
    #74
  15. TOE CUTTER
    Oil tank
    This cock sucker just does not fit and will have to regroup Thursday for the final fit but it is ready to go in. Will have to show it a bit of love as it is too wide at the base to fit between the frame and air box. Minor issue as it is close and a trip to the machine shop at work in the morning to spin it down a bit more is not a big deal.
    [/URL]
    #75
  16. TOE CUTTER
    Parts
    I am quickly running oot of parts. There is really not much to this kit and it goes pretty quick. I would give a time estimate at this point of ten beers total and a third were for reading. The instructions are good but a bit confusing in the wording but after going through this I think I have Dan's frame of mind and could do another kit for a different bike withoot the same problems.
    #76
  17. TOE CUTTER
    Stopping point
    I left it at this point and cleaned the garage and put everything away for a regroup. Still waiting on the radiator and grill, also the new clutch, windshield , dash panel,side dash panel and some hardware. Will finish the oil tank,fuel pump,down load the map, and start to clean the beast if the parts from uncle Ron do not show up in the morning.
    [/URL]
    #77
  18. TOE CUTTER
    Just asking
    I have been looking at other gen 6's and have not seen this on others but my windshield, inner dash panels and the dash itself have all cracked in a spider web fashion and had to be replaced. Junk. Thinking it is too many wheelies but I have never had this happen to any bike I have owned and all damage is noticed since SLO. Anyone else suffer this? Will post pic's if wanted. Part of the other repairs I mentioned earlier.
    #78
  19. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    Toe, you have such a way with words, I think this post should be nominated for a Pulitzer as I read it I feel I am right there in the garage with you. Got to go, getting all choked up with emotion, I feel like a bitch.
    #79
  20. MiddleAgeCrazy
    MiddleAgeCrazy New Member
    Kentucky
    Looks like you are really handy with a wrench and I am green with envy. I see from your avatar pic you have an 86 but with the swing arm off a newer bike? Like maybe a 91? Please direct me to the thread about that if there is one. You guys that are mechanically inclined I truly admire, I can't do it...
    #80
