Super Charger
Discussion in '6th Generation 2002-2013' started by TOE CUTTER, Jul 18, 2011.
  1. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    Slacker! This is worse than a strip tease. At least with the stripper I can throw a few more bills in the air and get some action. Here I'm stuck with no alternative but waiting to see the finished product.
  2. reg71
    Sikeston, MO
    you could probably try the stripper method with Toe, but buyer beware! He might start pole dancing on a golf cart and post those pics...
  3. Rangerscott
    Rangerscott New Member
    Texas
    So does the the supercharger use centrifugal force to circulate the oil?
  4. TOE CUTTER
    Not a clue. :unsure:
  5. vfourbear
    vfourbear New Member
    Cincinnati
    I bet it uses some form of midgets and glitter
  6. TOE CUTTER
    Toxic
    Toxic and his old lady had a falling oot and he came over for beers and ran the camera tonight.......a good thing as I was blowing and going......focused and pissed off. Would have not snapped a pic myself.......ready to put this to bed. No worries,the two of them are most likely bumping uglie's as I type. Love is fickle. Not sure what he was after with this pic. Looked at it again after loading it.....maybe I do.
    [/URL]
  7. Cogswell
    Cogswell New Member
  8. tinkerinWstuff
  9. TOE CUTTER
    Radimatator
    Got a radiator locally that was is very good shape and did not have to rob the one off Bweiss's bike , but bless him for the good looking oot. Painted it semi gloss black and bolted it on. A rather tight fit on many levels but it does fit and the tight spots are not critical as far as wear and future leaks are concerned.
    [/URL]
    [/URL]
  10. tinkerinWstuff
  11. TOE CUTTER
    Water Wetter
    Filled the cooling system and and added the Water Wetter as suggested by Dan. It is a product I have used for over 15 years and not only swear by it but will sing from the tallest mountain it's praises as a gift from the cooling system gods. It really does work. You can see the pink/orange bottles sitting on the table behind the bike......
    [/URL]
  12. TOE CUTTER
    The bike did not need both bottles......a little goes a long way but I am one to stock up . Better to have it and not need it than to need it and not have it.......also my theory on guns, ammo, and canned food. Really just can't go wrong I am thinking.
  13. tinkerinWstuff
    :hss: Fixed
  14. TOE CUTTER
    Ran the bike and purged the cooling system and ran it for a bit to check the belt alignment, leaks,and other things of concern that will make my ass pucker up. All good. Now to the part I feared the most and for good reason.......mind fucked myself into thinking I was mind fucking myself and all would go well......when all set and done I should have not mind fucked myself......this really went badly......body work is just not my cup of tea and WAY OVER THINK IT! First attempt. Looked good for a minute.
    [/URL]
  15. TOE CUTTER
    Ocd
    Attempt #2.....closer but no dice.......I thought things were still going well at this point.
    [/URL]
  16. TOE CUTTER
    Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm........not angry....yet....but getting there fast. The fit was tough as I wanted to have it mocked up to get and idea of exactly how it all fit and the clearance needed........those plastic locking tabs will push your very last button.....seriously.....the last one....over and over and over again. I did order 10 of those little prick's as I knew I was going to need them before this was over.
    [/URL]
  17. TOE CUTTER
    Tired and done. BBL.
  18. Fazer1Sniper
    Fazer1Sniper New Member
    :popcorn: This is epic...
  19. NorcalBoy
    what is that thing projecting off the left rear set?
  20. TOE CUTTER
    My left or your left? Brake or shifter side?
