Supermoto Build
Discussion in 'Mechanics Garage' started by NorcalBoy, Nov 12, 2015.
  1. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Great thread, thank you for sharing! Plus 1 on the Mad Skills!!!:eagerness:
    John
    #41
  2. Gator
    Gator Member
    I run the Power Bomb header and Q4 set up on my DR 650, very nice sound. Did you see post 26 with gearing question?
    #42
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Good stuff Norcal. I love restomods. Its nice to see a bike get saved and then built back up even better than it was when it left the factory.
    #43
  4. Scubalong
    holy chiiiiiiiiit :faint2:
    Just found this threat
    Speechless....Soooooooo beautiful
    :hail: NCB :thumbsup:
    #44
  5. Scubalong
    +1 :thumb:
    #45
  6. NorcalBoy
    Got some garage time yesterday and today
    Went to work on getting the headlight installed and functioning. Had to make a little change to the wiring harness for the light. The harness had ring temrinals to connect the switch, so i chopped those off and added spade terminals to conect up to the HDB switch on the top clamp.
    I retrofitted a small HID kit to the stock headlight shell and lens, as the stock headlight isn't really useful
    I drilled and tapped the ballast to attach it and used blue anodized Ti ProBolt hardware to mount it all up nice and clean
    Got the Shorai installed and tested it out
    Next I proceeded to make up a couple small harness items to connect the rear taillights to the stock harness
    Got 'em all hooked up
    It's kind of busy so I'm glad there isn't a whole lot more that needs to be conected to the battery...just the fan and the Vapor computer harness is left for now.
    #46
  7. NorcalBoy
    Continued on with some carbon parts I had stashed away until the day came where they could be installed
    Lightspeed engine case guards went on first
    Right side, luckily it had more than enough clearance from the oversize waterpump kit
    The left side had to be modified a little to clear the AN fitting for the oil cooler connection
    Then the carbon frame guards were installed
    Left Side
    The right side has an integrated guard for the rear master cylinder
    Next a carbon composite mud guard was added. The guard had to be trimmed to clear the vertical chain slider block
    Today I cut the chain to length and got it installed
    Next the Hammerhead case protector and Lightspeed carbon sprocket cover were installed with Ti Pro Bolt hardware
    last, but not least, the Hammerhead shift lever was installed
    I also put the main fuse in and checked the operation of the starter motor, just gave it a quick bump, but that whole circuit is now up and functional too.
    I'm hoping that my electrical stuff got delivered today and I should be able to mostly wrap the hard part up....ordered a new stock seat and a Guts Racing stepped seat kit for it and a 14t countershaft sprocket, the 15t puts a lot of stress on the lower chain roller, which I didn't like, so I ordered a Rentahl Ultralight 14t from CRF's only today and I should have it by Friday.
    #47
  8. NorcalBoy
    Thanks you guys, I appreciate the kind words. The original intent wasn't to go this far with it, but I got started and just decided to go a little nutty. It sat for the last part of 2013 and all of 2014 because I decided to buy a house and move. So I've been redoing a lot of the house, but seeing it in the garage, I just decided to get it done in 2015. Once it's done I can do some more upgrades to the house and I'm considering a new bike for next year.
    #48
  9. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Please do another vfr800. The last build was awesome. Take it even further next time around. What ever happened to your VFR?
    Sent from my A0001 using Tapatalk
    #49
  10. NorcalBoy
    Sold it to a member here, JTC. Thinking about buying something in an SP version that comes with the Ohlins, Brembo, modern elctronics package and is 90% complete from the factory.....and something that doesn't weigh 500 pounds....
    #50
  11. Willasan
    Willasan New Member
    Santee, CA
    I'm really enjoying following this. Thank you for taking the time to post up the pictures and descriptions.
    #51
  12. duccmann
    Wait, what...a VFR build...how did I miss that?
    That thing is SICK
    #52
  13. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Where's the fun in that? Lol
    #53
  14. NorcalBoy
    It was many moons ago and I'm not sure the pictures exist here anymore.....maybe they do?
    #54
  15. NorcalBoy
    Thank you for taking the time to check it out. Glad to see that some people are liking the thread.
    #55
  16. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I wonder if jtc is still active on here
    #56
  17. Alaskan
    Alaskan Member
    Alaska
    Even if I had the skills and vision, my wife would veto this out of the gate . . .
    #57
  18. NorcalBoy
    Poor is the man who's pleasure depends upon the permission of another.........:caked:
    #58
  19. duccmann
    I want that bumper sticker....
    #59
  20. OOTV
    OOTV Member
    He chimes in from time to time and has been to a few R3 events, although he missed this year's R3.
    #60
