Supertex Build
Discussion in '1st & 2nd Generation 1983-1989' started by supertex, Sep 9, 2009.
  1. rc24rc51
    rc24rc51 New Member
    Liberty SC
    The exhaust port gaskets might be copper in which case you should be OK but it won't take much to line everything up. I've done this a number of times. Use a little grease on the joint where the pipes meet inside and out.
  2. TOE CUTTER
    Wow those angles are bad.
  3. supertex
    supertex New Member
    Well..... my backs a little sore but with the use of a well placed ratchet strap, loosening the front 2 headers, some lubricant and a lot of rubber mallet action I got it on. I have to do some modding to the rear sub-frame so I can attach the exhaust can. Will get the carbs off and cleaned this week, replace the boots with the new ones I got, and button the last bits up.
    I see the massage chair at work in my future tomorrow.
  4. hopit88
    hopit88 New Member
    Way to stay with it. I find my big hammer is one of my favorite tools.
  5. TOE CUTTER
    Does this mean your going riding now?????????????????????????????????????????????
  6. supertex
    supertex New Member
    As soon as the carbs are cleaned, I have to fabricate a bracket to hold the muffler. If I can make a temporary one can you weld a permanent piece in for me? :pray:
  7. supertex
    supertex New Member
    Cleaned carbs and re-installed with new carb boots. Now to take a grinder to the sub-frame.
  8. supertex
    supertex New Member
    So as always when I have something apart I can't stop messing with it. Yesterday I ground all the passenger pegs off and smoothed it out, cut off the rear mud gaurd, and fabricated a license plate holder bracket. Went to put the sub-frame on the bike for exhaust bracket fab and it isn't lining up correctly.......confusing. The right side is hanging down lower than it should. Will un-F that then begin bracket work. WTH
  9. supertex
    supertex New Member
    Almost almost almost
  10. crustyrider
    crustyrider New Member
    North Country, New York
    what the hell did you spend the night at Toxic's place and catch a case of the crabs?
  11. supertex
    supertex New Member
    lol saw this and laughed very hard so I had to post somewhere.
  12. TOE CUTTER
    I am not even gonna ask.
  13. supertex
    supertex New Member
    Ok finally got everything back together I think. Charging the battery now; already charged the carbs, will check tires and what not after it starts. I love the single higher exhaust.
  14. supertex
    supertex New Member
    Well........suck. Battery fully charged key in and TURN; made the clicks but didn't even try to turn the motor over. It's acting like something's not plugged in but I'm sure it all is.
  15. rc24rc51
    rc24rc51 New Member
    Liberty SC
    the battery may be shot regardless of what it's showing. Have it load tested before you do anything else.
  16. TOE CUTTER
    My money is on toasted battery, how old is it?
  17. supertex
    supertex New Member
    Was brand new when shock was lost. It's lighting everything up and I'm not having much loss when attempting to start. Meaning the lights aren't dimming much when I attempt to turn it over.
  18. TOE CUTTER
    If it sat discharged for more than a couple of months it is shot. How long ago was the shock lost?
  19. supertex
    supertex New Member
    A year?! Sad I know. I will go backwards and figure out if I made all appropriate connections before I believe it's the battery.
  20. TOE CUTTER
    If it sat for a year just stick a fork in it...........it's done. :hungry:
