Supertex Build
Discussion in '1st & 2nd Generation 1983-1989' started by supertex, Sep 9, 2009.
  1. supertex
    supertex New Member
    One more with different tank and new windscreen from e-bay by way of Toecutter. Maybe it's just me but that screen gives it a late model Kawi look to me. I have since done a little something to the screen that I think I like so we'll see what everyone else thinks later.
  2. supertex
    supertex New Member
    Got some wheels folks. Rear from a CBR F2, front from a 5th gen since Toe has so graciously donated some forks and brakes from that bike. Got them powder coated and cleared through a friend of Toxic's. This color will be easy to clean and will look pretty good with the mostly white and red paint scheme I'm going with. Got a smoking deal on both of these wheels. rear came with everything including hub sprocket and rotor, all for $65 shipped. Front came with rotors as well for $95 shipped.
  3. supertex
    supertex New Member
    After receiving some spacers and my Fox shock rebuilt from Jamie, we started the install of the rear. Quick note: if you are going to use a caliper from an F2, which I do suggest, ask Jamie to make a 8mm spacer to make up for the difference in brake bracket width. We drilled an tapped the bracket to attach the brake arm. If you do it this way you don't have to bend anything or worry about braking anything.
    Thrown in there for a test fit
    Brake arm drilled and tapped.
  4. slowbird
    slowbird Member
    Toronto, Ontario.
    Wow....everything is coming out very very well.
    Keep it up guy...kudos! :thumbsup:
  5. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    damnit mex...finish it all ready!!!! I've been waiting too long!
  6. supertex
    supertex New Member
    :bump: .................
  7. TOE CUTTER
    Supermex's muffler bearing
    Move the muffler bearing mount back and mounted said kunooter valve assembly.:biggrin:
  8. supertex
    supertex New Member
    Thanks Toe!!! :thumbsup: Toxic too!!
    How great is it to have skilled generous friends?!?!
  9. TOE CUTTER
    subframe
    I will pull the sub frame off and fix the paint and touch up the engine and pipes next.
  10. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Did you swap your steering stem in the triples yet? (your stem -> 5th gen lower triple?)
  11. supertex
    supertex New Member
    Yeah. I haven't seen it yet but I think Toe picked it up from the machinist.
  12. pokerplayer6989
    pokerplayer6989 New Member
    missouri
    ok toe mines next, be recieving by crate in the next two months lol:biggrin:
    its coming along nicely tex:thumbsup: cant wait to se finished product.
  13. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    tex awesome job on the bike so far you west coast guys sure now how to build a kick ass looking bike that thing is going to be a beast when it gets done great work love that tail you fab'ed up :thumbsup:
  14. supertex
    supertex New Member
    Would I tell you your girls mine next just because you said she could cook in the kitchen and out? No..... No I don't think so.
    Hands off. :fencing:
    All joking aside I couldn't have gotten this far without the Sac crew. :thumbsup:
  15. TOE CUTTER
    Time, or lack there of
    I will pick up the triple Thursday afternoon and change the fork oil and put the front end on friday night,clean up sub frame ,wash,touch up paint and clean up the wiring,and replace a few bolts that are pissing me off.Shit,and fix head light...just remembered....then I am done....Saturday morning and I will be ready to see some body work....and a few beers!Bring a helmet Tex!:thumbsup:
  16. supertex
    supertex New Member
    Body work
    Alright some work to the panels needs to be done. The paint job won't be the best in the world
    because I need to finish it now for my trip to Long's so bear with me. Both side panels were about
    the same condition. The Paint will be white for the moment.
    Upper cowl after some major sanding. I'm gonna close up the marker
    holes so I can put in newer style LEDs.
    First panel had some missing material on the air scoops, and a
    broken piece at the middle connector hole. Second panel has
    already had a ton of sanding and primer and now a white top coat.
  17. TOE CUTTER
    Lowers
    That lower looks good! Hooker.:thumbsup:
  18. supertex
    supertex New Member
    Thanks slut
  19. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    So, you're not doing all this work yourself? Who's doing what?
  20. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Nice Tex, I've enjoyed this thread very much!
    BZ
