Supertex Build
Discussion in '1st & 2nd Generation 1983-1989' started by supertex, Sep 9, 2009.
  1. TOE CUTTER
    Hurry up slacker! :hss:
  2. supertex
    supertex New Member
    Well Fox shock has been at Jamies, but we are waiting for a donor from Illinois to arrive for reservoir attachment. Getting antsy.
  3. hopit88
    hopit88 New Member
    Please explain your issue.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    he is waiting for a reservoir tip to arrive so Jamie can stick it......... to the hose.... sounds like it got sheared bad enough that the original one won't work.... but that's just my guess...
  5. supertex
    supertex New Member
    Well the ENTIRE reservoir was sheared off 6" up the cable. Found a donor off a CBR in Illinois and the guy finally texted me yesterday saying he was shipping it out. The CBR unit isn't correct length for the F2 so Jamie's gonna use this reservoir and attach it to my main body giving me a whole unit. Theses shocks are practically impossible to find. Used a Craigslist finder to find this one.
  6. TOE CUTTER
    :bored: hurry up!
  7. hopit88
    hopit88 New Member
    Gotcha, Fox stuff is hard to find. For future reference, I got all my parts here. 2.0 refers to the diameter, that's what mine is, probably yours as well. .625 is the shaft size. They have just about everything you'd need for shock parts. Might beat having to find a donor again someday. I may end up getting a longer res line for mine.
    Fox Shox Parts
  8. supertex
    supertex New Member
    Sweet. Thanks Hop. Link looks like all auto off road stuff. Parts cross over?
  9. hopit88
    hopit88 New Member
    The parts will fit as long as the dimensions are the same. Like I said, mine is a 2.0 with a .625 shaft so all the o-rings, seals, wear bands, etc will fit. Same goes for the res.,res end caps, floating pistons, hoses, valving, pistons, etc. They got my stuff out pretty quick and there's even a rebuild vid on there that helped. Just thought I'd throw it out there if anyone needed it.
  10. supertex
    supertex New Member
    WooHoo!!! The shock finally reached Jamies' so I should be on my way to a functioning bike!
  11. hopit88
    hopit88 New Member
    Awesome!
    Did it arrive by stage coach?
  12. supertex
    supertex New Member
    Think the mailer went on a walkabout to find a post office.
  13. supertex
    supertex New Member
    Shock!
    Right on! Jamie is done with my shock. So after postman brings it, I'll be BACK ON THE ROAD!
    Thanks Jamie!
  14. rc24rc51
    rc24rc51 New Member
    Liberty SC
    2 gen resivour location
    I mounted the shock res on my 750 like this. The AMA race bikes back in the day were set up the same way. View attachment 16454
  15. supertex
    supertex New Member
    Thanks RC, I'll have to check that out.
  16. TOE CUTTER
  17. supertex
    supertex New Member
    I hope I remember how to put it back!
  18. supertex
    supertex New Member
    As if by the gods my shock hath arrived! Mon or Tues it should be done. Barring I don't break anythig else in the process. hehehe
    Took old sticker off to see main body housing. Very pleased. only 1 little mark.
  19. TOE CUTTER
    Weather is nice, a bit chilly, you gonna ride oot for a visit/ride this weekend?
  20. supertex
    supertex New Member
    Working all weekend and wrenchin in the garage tonight. Maybe next weekend if I can swing it. God I took a lot apart for this damn shock! :crazy:
