T3 - Tinks Annual Project Bike ('98 VFR800)
Discussion in '5th Generation 1998-2001' started by tinkerinWstuff, Oct 24, 2011.
  1. tinkerinWstuff
    I'd probably be riding the project bike around today if I had a shim kit... :potstir:
  2. tinkerinWstuff
    camera phone pic sucks
  3. Fazer1Sniper
    Fazer1Sniper New Member
    It's BLACK! Looks great Tinker.
  4. tinkerinWstuff
    my new/used clutch cover came today too. But not the gasket to put it on. Or my new front wheel bearing seals so I could put the wheel on.
    soon I will be rid of that fugly scraped up engine case.
    All the swingarm bearings and seals are here though.
  5. Porkchop
    Porkchop New Member
    Worthington, Ohio, United States
    I can't wait for this to come together....
    I forget, were you spraying your own paint again?
  6. tinkerinWstuff
    yes. it's as close to the US 2000 VFR yellow that I could get in a single stage paint. It matches perfect in the light but is a little off in the garage.
  7. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Flourescent lighting allways throws colors off, it DOES however show each and every flaw, so it's the place to wetsand and buff if you're so inclined, then it looks beyond perfect in the daylight, even with a few small boo boo's that can be seen in the garage. Lookin freekin fantastic BTW.
  8. pap11y
    pap11y New Member
    Sydney
    so....... :)
  9. tinkerinWstuff
    wire harness is kicking my ass. Appears gen 6 moved many electrical components to the front. Not much room in the tail to stuff computer, fuse box, relay, etc...
    I unwrapped the harness to rebundle and route things where I can fit them but still struggling.
    Gen 6 used different connectors on the ECU so picking up a different harness doesn't appear to be a simple solution.
  10. pap11y
    pap11y New Member
    Sydney
    Ouch. Sorry to hear about that.
    Hope you have it sorted soon..
  11. tinkerinWstuff
    could never have guessed the level of difficulty the wiring would pose.
    but failure isn't an option at this point so it will get figured out if I have to wire it from scratch.
  12. pap11y
    pap11y New Member
    Sydney
    If it wasn't a challenge it wouldn't be worth doing..
    You'll get it (but damn its frustrating when you have shit like this that you didn't expect holding you up)..
    I feel your pain..
  13. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Keep going bud. I want to see this when it's done. I looked at your 3rd gen thread recently and I must say you did a nice job on that one.
  14. tinkerinWstuff
    is not a clear window cover but is closer to my budget at this point and not rashed:
  15. DaHose
    DaHose New Member
    Napa, CA.
    Hey tink. Are you gonna sell me that "fugly" cover?
    I hear ya, mang. Electrical is ALWAYS the biggest nightmare.
    Jose
  16. tinkerinWstuff
    PM sent :cool:
  17. Pops
    Pops New Member
    Stephenson, VA
    Judging from that side cover being in a baking pan...are you baking on high-temp paint, or do you have a DIY powder coating setup?
  18. tinkerinWstuff
    just attempting to speed up the cure on high temp engine paint
    also ordered another wiring harness yesterday and will do up a wiring board to try and reorganize a custom harness
  19. ridervfr
    You gots dah little woman involved in your project as a holder???? FAR OUT!!!
  20. tinkerinWstuff
    she did help put the thermostat housing back together. I changed the T-stat, tightened up all cooling hose clamps (every one was loose), and did the valve gap inspection, all while the frame was off. Attempting to change the t-stat thru the side without removing the throttle bodies or disconnecting the hoses was a M-F'r and hardly worth the trouble. Couldn't have got it back together without the wife's small fingers. If I had to do it again, I'd probably just bite the bullet and pull the throttle bodies.
