T3 - Tinks Annual Project Bike ('98 VFR800)
Discussion in '5th Generation 1998-2001' started by tinkerinWstuff, Oct 24, 2011.
  1. tinkerinWstuff
    parked at Tubes and Hoses guy's shop for custom brake lines.
    Project so far over budget that I only sprung for new hoses on the rear. Hoping that going with steel braided lines on the rear does not noticeably offset the balance of the linked system with rubber still in the front.
  2. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    What?! These types of projects have budgets??? :tongue:
  3. duccmann
    a little pricey huh ---- Looks like those mirrors with the LED turn signals ! Cant wait to see her finished
  4. vfourbear
    vfourbear New Member
    Brazil
    Cincinnati
    It will upset the balance Tink. But not so much that you will really notice since you're going to tour this bike. Not trying to tell you what to do......
  5. tinkerinWstuff
    Good bargain. $170 to get the custom lines done. He figured $200-$250 to do all the fronts and clutch if I pull them off and bring them in for replicas. Hopefully this next winter....
    So here's the stock steel lines cut and spliced with new to route better with new subframe mounts and rear master location
    Rear master with lines now and the header wrap installed. :dance: I'm waiting on the brake light pressure switch to arrive on Monday before I can bleed the system.
    And the purdy new braided lines
  6. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Looks good man!
    Oh, and hey... I was just being a wise ass with that budget comment. I know how these things tend to grow and it's not fun when it exceeds what you expect.
    I have set aside $3,000 for VFR and 954 repairs and upgrades. We will see how that goes...
    Sorry about my smart-assed comment.
  7. SA1713
    SA1713 New Member
    I can ship you a set of fronts I have sitting in a box. That way you don't have to tear yours down and wait.
  8. tinkerinWstuff
    That would be a big help. I was thinking of buying the braided line right away because each run of hose comes in with a different shade of color. Having a donor set would allow me to buy the right amount of line right away. It would also make installation much easier as opposed to trying to match up to photos.
  9. tinkerinWstuff
    Took her out for a first run tonight and had a close call
    [video=youtube_share;WqXSls7iO7M]http://youtu.be/WqXSls7iO7M[/video]
  10. Fazer1Sniper
    Fazer1Sniper New Member
    Rabbit or El Chubacabra?.....
  11. tinkerinWstuff
    ^^ well he seemed a lot bigger than your normal rabbit until I went back and watched the video
    Here's my mounting of the RR. Had to drill a hole in the heat sink to clock the RR in such a way as to clear the bend in the aluminum fairing mount bracket.
    Rode to Denver and back today without any problems. I have a minor fuel leak at the fuel level sensor mount flange o-ring. Just have to mount the ECU and I can put her clothes on.
  12. Scubalong
    Wow that is a great achievment..........My hat out to you Sir:hi2::hail:
  13. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Have you thought about stick coils? It might clean it up a bit.
    Then again, you a probably ready to be done with the project, eh?
  14. tinkerinWstuff
    won't see them when the plastic is installed and any more time spent in the garage with this thing and I'm liable to find myself in divorce court.
    Hopefully I'll have photos to unveil in the next two weeks.
  15. ridervfr
    Remeber ancient Chinese saying, "a Happy wife, equals a happy life."
  16. tinkerinWstuff
    think nothing of it. no worries :thumbsup:
  17. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Cool, bro. <knuck bump>
  18. reg71
    Sikeston, MO
    just finish it so you can get your ass out here...
  19. Bryan88
    South Africa
    Durban, South Africa
    Fabrication and even engine work is one thing but electronics and wiring looms, now that takes serious bravery. Well done man!
  20. TOE CUTTER
    I second that, your milking it now.
