T3 - Tinks Annual Project Bike ('98 VFR800)
Discussion in '5th Generation 1998-2001' started by tinkerinWstuff, Oct 24, 2011.
  1. tinkerinWstuff
  2. vfourbear
    vfourbear New Member
    Brazil
    Cincinnati
    Well.........I kinda like it.
  3. acwelch
    acwelch New Member
    Knoxville, Tennessee, United States
    Gorgeous! Read this thread today while at work. Nice nice nice nice job! Hope mine can turn out this well. Question... that whine that was talked about on the first page, is that normal for this bike? Or a sign that something is going wrong?
  4. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    Something wrong? Certainly not. That gear whine is pure music!
  5. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Just add cheese.
  6. tinkerinWstuff
    Box-o-braided lines. Finally replacing the fronts and clutch.
  7. ridervfr
    So, the carpet matches the brake lines. Used to say that about wimmins bushes matching their hair colour too, think that was carpet matching the drapes though. If you dont laugh at that shit, you dont have a pulse. :pound:
  8. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    That's a sexy box ya gots there Tink.......................:party2:
  9. Durk
    Durk New Member
    Pittsburgh, PA
    So Tink what weight sledge will you use to torque the banjo bolts with?
  10. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Excellent job there Tink, you have a power for creation that I for one am a little envious about. If your son turns out to be half the VFR customizer you are there will be a force in Colorado to be reckoned with.
  11. tinkerinWstuff
    I will have to check the book spec and then convert ft/lbs to ounces.
  12. tinkerinWstuff
  13. ridervfr
    I can understand why you were'nt motivated/excited to install those brake lines. Royal PITA huh, I'll stick with my low-tech braided lines. Bike looks good :madgrin:
    You gona hit the "million dollar highway" with it one day?
  14. tinkerinWstuff
    The lines by themselves probably wouldn't be so bad but I'm replacing the fairimg stay and headlight assembly. Also sync the starter valves, clean the air filter, oil change and installing a knockoff double bubble windscreen.
    Haven't made plans to hit the 550 this year. But things change quickly and it could happen. Rode it 2up on the shadow a couple years ago.
  15. Metallican525
    Rockville, Maryland
    Schmexy lines, what's the decal at the bottom of the fork sliders?
  16. tinkerinWstuff
    STM Suspension | Motorcycle Suspension Tuning in Northern Colorado. Authorized dealer for GP Suspension and Ohlins.
    Also, I added a toggle switch to the check engine test point of the wiring harness. After building the custom harness, the test point ended up right by the headlight and impossible to access without removing the front cowl. Now with the toggle switch, I will be able to remove the right side fairing to flip the switch and read FI codes.
  17. Metallican525
    Rockville, Maryland
    Yeah even in the stock location it seems the test connector is a real pain in the pecker to get at, good idea!
  18. JES_VFR
    JES_VFR New Member
    Well I wish I had seen this when you first started the thread. Thanks to trading away my RC51 for a 2nd 5th gen, I have 3 spare stocks seats and 6 more tail cowls than I can possibly ever use. I could have gotten you going with 5th gen parts for a great price.
    Now on the 6th subframe helping with touring, I have to agree, the luggage mounts are in close and contribute to a narrower aft section compared to a 5th gen with Givi's... even if you used the new Givi cases on it instead of the Honda branded bags, IIRC its still narrower than a 5th with e360's.
  19. JES_VFR
    JES_VFR New Member
    I thought that right off the bat myself.
    I stuck in a set of CBR600 stick coils and chopped up the CBR coil harness for the four coil connectors.
    Put them in just matching the oem VFR female spades, but since they worked flawlessly for now, I'll solder them in with splice joiners and heat shrink this winter.
  20. JES_VFR
    JES_VFR New Member
    Not up here it doesn't..
    "a Happy wife, equals no life"
