The restoration has begun... Now the questions!
Discussion in '1st & 2nd Generation 1983-1989' started by Salvo, Apr 10, 2009.
  1. Salvo
    Salvo New Member
    Mesa,Az
    I was out cleaning more parts today and noticed that the clutch master cylinder is broken where the handle pivots, it's junk for sure... this leads me to this question, Are other manufacturers clutch assemblies, such as Suzuki or Kawi's compatible with Honda's? Or maybe I should ask whether or not handlebar tubes come in different sizes or is it a industry standard to have one size fit's all??? I don't know yet if I can buy replacement clutch/brake master cylinders from Honda or Bike Bandit. If not, any idea which ones from other Hondas will fit?
    Also, what about clutch fluid lines, Do they make a stainless flex line to replace the rubber and metal tube line that is on the R model?
    While I'm at it... Water hoses, Do any of you know if there are still replacements available from Honda? I haven't gone to the library yet and made copies of my microfiche... Thanks!
    #41
  2. josephvh
    josephvh New Member
    AZ
    Salvo, I'm down in Yuma.
    #42
  3. Salvo
    Salvo New Member
    Mesa,Az
    Just an update for the thread... I've been busy scrubbing parts in the tank and getting my sandblasting setups ready. I plan to beadblast the frame soon and will get a coat of urethane semi-gloss black layed down and install the new head bearings and go from there...
    I am thinking about doing away with the TRAC unit and installing the "Gold" accumulators from RaceTech unless someone gives me a reason not to... I thought I saw someone on here do that, was that you VFRCapn?
    I am still waiting to hear from you guys on what to do about clutch/brake master cylinders and what will/will not fit my handlebars? And also about the clutch line....
    I have still been buying parts off Ebay... Got a nice lower coming to replace my beat up one... it's got a couple of small places to fix but way less than mine...:biggrin:
    I would like to ask you guys who own these model bikes what tires you run? And why? I have been perusing the tire sites and don't know which ones to pick, so who better to ask than the peeps that have them now!
    I went to the library today and made copies of my microfiche, now to compose a list and hit Honda up to see what they actually still sell...
    Sorry no new pics, there just isn't anything groovy happening yet... Take care and thanks for the input to the questions! Salvo
    #43
  4. Salvo
    Salvo New Member
    Mesa,Az
    I went out this morning and welded up a framework to suspend the bike frame from when I paint it... Then proceeded to get out the blaster and have a go at the frame... it cleaned up fairly nicely, now to get a coat of etching primer on it and go from there.
    I won a sweet fuel tank on ebay today, that about does it on the updates for now.... :cool:
    #44
  5. Salvo
    Salvo New Member
    Mesa,Az
    I layed down a couple light coats of etching primer, letting it dry, then will lay down some primer-surfacer coats....
    I also got in touch with Dave Dodge about future engine machine work, I can't wait to get started on that!
    I think that I have changed my mind on the paint scheme. The more I look at my sketches the more I think about going with a variant of the Rothman's scheme... Instead of the blue maybe trade that for a version of candy pearl mango/orange...
    'til next update...
    #45
  6. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    dude you should have covered the threaded holes with tape or somthing, just by running a tap through them it should be fine! :thumbsup:
    #46
  7. Salvo
    Salvo New Member
    Mesa,Az
    I always run taps thru the holes after painting anyways, but thanks for keepin' an eye out for me! :thumbsup:
    I just got done with 3 coats of surfacer, didn't snap a pic... I'll wait until I get the metallic silver down...
    #47
  8. Salvo
    Salvo New Member
    Mesa,Az
    I got the frame wet sanded today in preparation for painting tomorrow morning, snapped a couple pics just because... :rolleyes: I'll snap some more after the paint... Waiting on my rim savers to show up and I'll get the tires off, then bead blast those... I'm planning on powdercoating them.
    Umm, what else... I also got the triple clamps bead blasted and primed today, those will get a nice coat of gold to go with the Rothmans scheme...
    #48
  9. hopit88
    hopit88 New Member
    See if you can get a low temp powder coating. I heard of a guy who had his R rims done but had the outer bolts loosen up. Possibly the steel spokes and the aluminum rim "moved" differently during 400 degree baking? You cannot retighten them. He ended up replacing all the bolts, something I would be very nervous about.
    Love the stand!
    #49
  10. Big3
    Big3 New Member
    Lancaster, Ohio
    pretty sure he's powdercoating the F2 wheels not the stockers
    #50
  11. Salvo
    Salvo New Member
    Mesa,Az
    I will be using the stock R rims. I have considered going to the F2's but for some reason I just can't see them on the R...? Even though I can't get a decent sized tire for the rear, I still love the way the wheels look! Maybe I can fit a 150 size tire at least? I will check into the powdercoating issue, it was in the back of my mind and I really don't want to play with my safety. I would however like to replace those bolts as some of mine look a little weathered. If anybody has any info on getting replacement bolts I would love to hear about it! Right now if I can't powdercoat, then I will have to mask off each bolt and nut and see about some kind of metallic shade of paint... I think Eastwood Products offer something close enough to the patina of metal polishing that would suffice... we'll see. Thanks for the info on the powdercoating though, got to keep it safe!
    B.T.W. hopit, I like your little project too!.. would love to know more about that exhaust system, i.e. about bending the pipes??? I am contemplating bending up my own stainless system...
    #51
  12. Salvo
    Salvo New Member
    Mesa,Az
    I got the frame painted this morning and also layed some color on the triple clamp... I'll let these sit a week or so to air out and start to go back together.... WOO HOO!!!!!!
    #52
  13. Big3
    Big3 New Member
    Lancaster, Ohio
    I stand corrected on the wheels .. I figured since you upgraded the front forks you were going to upgrade the available rubber also ...
    #53
  14. Salvo
    Salvo New Member
    Mesa,Az
    Hey Big, I think you might have my thread mixed with another... I haven't gotten into my forks yet... I am planning on ditching the TRAC system and going with some RaceTech Gold Emulators though.... :thumbsup:
    #54
  15. Salvo
    Salvo New Member
    Mesa,Az
    Heres an update for the week... I've been bead blasting the various metal and aluminum pieces getting them ready for paint, primer is drying on some of them as we speak... I got the swingarm blasted and a coat of clear on it, looks good! Here are a couple pics of my rear shock, I think Jamie said it was a Fox "clicker"... Can anybody identify it for sure? I can't find any numbers on it and want to have it rebuilt.... Jamie, if you see this, are you still offering your rebuild service? and cost $$$ ? It seems like it still has plenty of pressure in it but as long as it had been sitting I don't trust it... and I want to have the resevoir re-anodized anyways.
    #55
  16. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    Looking good! :thumbsup:
    Definitely looks like a Fox shock worth saving. Where are you located? I have a local shop that I believe rebuilds the Fox shocks.
    #56
  17. Salvo
    Salvo New Member
    Mesa,Az
    I'm in Mesa,Az... Any ideas on how to take this system apart as far as the resevoir is concerned? I would like to have it anodized before sending the shock out for rebuilding...
    #57
  18. supertex
    supertex New Member
    #58
  19. matt1986vf500f
    dude send it to jamie he's the man when it come's to shocks and forks i still am blown away with my rear shock on my bike! it's worth the time and money trust me bro...keep us posted bike's lookin great!
    #59
  20. Salvo
    Salvo New Member
    Mesa,Az
    Thanks for the link SuperTex! I'll study it for a bit and maybe I'll just attempt to do this... I found a page for a rebuild kit at $20.00 for the parts... Thanks for any of the comments guys, they mean alot to me! I need you guys for backup, I can ride and I can paint but as far as the internal mechanics... this is the first time that I have taken a bike project this far, in alot of ways I'm venturing into unchartered territory for myself. I hope you can appreciate my effort at restoring one of the "Great!" bikes out there. I want to see this one survive!
    #60
