The VFR that wasn't but now is.
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Oct 19, 2021.
    That left is just the shaft and a needle bearing (for the chain drive forces). The right side has the ball bearings and spacers to control side-to-side movement.
    Wheezy and RogueRC24 like this.
  2. RogueRC24
    great!! I am going crazy trying to make sure I don't miss anything. :)
  3. RogueRC24
    New exhaust head bolts installed. They don’t seen tor want to torque out so I ran them in until they were the same length as the older ones.
    Cut off the old race finally. A little nick on the stem but should be fine. Keep on pushing. image.jpg image.jpg
    Captain 80s likes this.
    Have you cracked the starter open and flushed out all of the brush dust?
  5. RogueRC24
    Wheezy likes this.
  6. RogueRC24
    Negative. I will put it on my list. I place a new oring. I will go back
    pull out the brush part?
  7. RogueRC24
    New exhaust gasket installed and cool ass long bolts for header install. Leaving a little loose until it is go time. Better half got to lightly punch exhaust “clamps “ while I held the headers.
    Hose everything down with electronics cleaner. The windings and the case with the magnets too. Clean up the armature with red erasure. Maybe lightly sand the brush faces for a fresh surface to reduce making groves.
  9. RogueRC24
    All torqued and mounted!! Been waiting for this day! image.jpg image.jpg image.jpg
    Lower case cover to be power coated in the near future. Penske still in process, so continue on front end for now. Time to press bearing onto lower.
    Wheezy and Thumbs like this.
  10. squirrelman
    OMG that steering stem took a beating :eek:
  11. RogueRC24
    Need to purchase some pipe to press on my stem bearing. Boooo
    I did find these washers with built in rubber. Any thoughts on where these go? Done for tonight. Good progress. image.jpg
  12. RogueRC24
    SM,
    Well it is my first time on everything so I have what I have. Hardly think those are going to make this bike from fall apart. With all of the other metal taking the load I should be good.
    Pretty damn sure those washers are for the rear brake torque arm shoulderded bolts. The rubber just happens to be stuck to the washer, not actually vulcanized to them.
  14. RogueRC24
    I believe you are correct on both accounts now that you mention it. I bagged and tagged a lot of critical parts, but like a moron I unpacked a few bags at one time so my "swing arm" stuff got mixed with "frame" stuff. Off to a car show and hardware store for pipe +.
  15. RogueRC24
    Thermostat matter for pin hole? image.jpg Torque spec on exhaust nuts? Just M6 rating? image.jpg
  16. RogueRC24
    Up off the deck finally. Fork painting tomorrow.
  17. straycat
    Nice Work !!! Looking really good Rogue!
  18. squirrelman
    good job ! check the fsm for the correct position of the bypass hole in the thermostat.
  19. RogueRC24
    ^^^ thanks SM and Stray! Today was about details and locating a lot of small miscellaneous things that I can improve with paint or correct un-weathered fasteners of my choosing.
    Radiator minus the guard that is drying.
    forks in black. Still curing and then seals + stickers tomorrow. Fan assembly in corroded.
    subframe mount.
    Need better hardware for lower mount points and rear sets.
    and my In & Out food tray I mean parts holder.
  20. squirrelman
    using an exacto blade or small knife and several hours of your life, you can straighten most of those bent radiator fins and improve cooling. i usually smoke a blunt and get deep into it, no rush.
