The VFR that wasn't but now is.
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Oct 19, 2021.
  1. RogueRC24
    UPDATE:
    Tire was corrected without adding damage....and shit just got real. PENSKE in the hizzle!! Arrived this morning. :) Just waiting on main right side engine cover and some rotors. Almost there!!
    That's purdy. Everything is looking great.
    RogueRC24 likes this.
  3. squirrelman
    that shock will double the value of your bike. o_O
  4. RogueRC24
    ^^hahahahaaaa
  5. straycat
    she's gonna be sooo nice Rogue !!
  6. RogueRC24
    Need input on reserve location. Obviously I don’t have the body work on but a preview would help.
    on a side note I have the plastic rear fender in and I even clean and painted the support bracket. Chain installed as well. Bling! image.jpg image.jpg image.jpg
    Thumbs and Wheezy like this.
  7. RogueRC24
    Also do I want to the heat shield between the front of the carbs and radiator? I couldn’t find it in my parts to go back on. I might have to steal from 7hundie.
  8. FJTom
    FJTom New Member
    Germany
    Oldenburg, Germany
    I'm thinking about a Wilbers with reservoir too, I woud prefer a place in the outside, perhaps somewhere at the left rear passenger footpeg. Just for temperature purposes.
  9. sixdog
    sixdog Insider
    I don't know if anyone has mentioned this but I really like the red valce covers....
    Are you going to run passenger pegs?
  11. RogueRC24
    No rear pegs and I was thinking maybe in the tool kit ( ? ) pocket behind the rear coils. Tools are the only thing I can think of that would go in there and I can line it with Shorai battery foam. Could care less if I had to remove the seat to adjust.
    never mind it it too much bend. I guess the usual mount to sub with clamps.
  12. RogueRC24
    Still moving forward. Penske res safely mounted, a stolen other project license plate tidy tail installed, and the tail bodywork. 2nd photo, is that the famed fuel pump whatnot to jump? image.jpg image.jpg image.jpg
    Wheezy likes this.
  13. Terry Smith
    It was traditional to mount the reservoir for a Fox shock along the left side frame spar. Your tucked-in location looks pretty good however, I have the reservoir on my 5th gen in a similar spot but on the other side (the cable ties were a temporary fitting check!); the PO had it hung off the left side below the body where it could bash into the chainguard on a bump!
  14. FJTom
    FJTom New Member
    Germany
    Oldenburg, Germany
    That's what I mean! Perfekt place.
    That does look like the Fuel Cut Relay. Can't absolutely guarantee on your bike, but it will likely be the 2 dark wires to jump.
  16. squirrelman
    ^^ on the '86 700/750 you jump blue to blue/black for power to the pump.
  17. RogueRC24
    Thanks dudes! What is your avatar SM? lol
  18. squirrelman
    this
  19. RogueRC24
    UPDATE!
    Front end done for now. Powder coat fail yet again. “Next week” … uh huh. Can’t even turn over the engine. image.jpg image.jpg image.jpg
    factory Honda exhaust hanger installed . temp until I get some welding and tie rods in. Shhh exhaust is sleeping.
    Ohh and happy 4th o- July! Except for Stray cause he might speak French.
    Wheezy likes this.
  20. RogueRC24
    Also does everything look ok here? When I removed the cover the metal bushing came off with the cover. image.jpg
