The VFR that wasn't but now is.
Discussion in '1st & 2nd Generation 1983-1989' started by RogueRC24, Oct 19, 2021.
  1. Thumbs
    Thumbs Member
    Bath(ish)
    2&1/2 is correct for a starting point
    As you’ve had the float valve seats out I assume you’re putting new valves in, the float height is 9mm for the 36mm carbs
    I’ve got the same bike and exhaust system, mine used to belong to a guy who raced F750 @ the TT in the 90’s, RC30 was his race bike and he used the FK as a road learning tool outside of official practice, he had a certificate on his wall for the FK from 1991 with a speed of 161 mph clocked down the Sulby straight …..so the OEM jetting must be pretty much spot on
    #61
    Captain 80s likes this.
    I don't think he's going to use the muffler, moving to a straight thru design, but I can't argue with that. Cool.
    #62
    Thumbs likes this.
  3. RogueRC24
    Me thinks I'm in deep.
    ^^thumbs. I have no new parts to put in besides the mini kit from V4dreams. I did inspect the rubber portion of the float valve (hangs off of the float bowl?) and they didn't have a ring or any oddities about them. I did clean them gently and check their little internal springy-ness. Seemed good so far.
    Is there a good source for these carb parts, or will this be a search and destroy google mission? Looks like you can order individual jets through 6Sigma.
    ^^161mph ...whew that is flying on that bike. 173 is my PB top speed.
    #63
  4. RogueRC24
    I have NEVER had to replace the Viton tipped float valves. Put a little lacquer thinner on a rag and spin the tip between your finger and thumb. The rag will be black. Move to a new moistened part of the rag and repeat. Maybe one more time. This will remove any deposits and get down to "fresh" rubber.
    #65
  6. squirrelman
    be sure to compare any new jets with your old ones side-by-side to check for errors, and be careful not to over-tighten emulsion tubes like this guy did............
    (undamaged part in the middle)
    #66
  7. RogueRC24
    Here is one of the float valves to my understanding. It looks good to me.
    this is the #125 main jet
    #67
  8. squirrelman
    best to inspect float needle with a 10X magnifier to look for a ring of depressed area or any defects.
    #68
    Thumbs likes this.
  9. Thumbs
    Thumbs Member
    Bath(ish)
    #69
  10. squirrelman
    cheap enuff but made in china junk can be wildly inaccurate. they haven't yet figured out the concept of quality control.
    #70
  11. RogueRC24
    lol, wrong pic. #38.. i swear I know what is what..jeezus.
    #71
    I have so many goddamn bikes, I can't afford to throw all new parts at everything, every time. An original float valve that passes inspection and operates perfectly on a bench test is gong back in. I would rather have a used Honda float valve that is still perfectly fine, than some potentially inferior part. I'm sure there a good replacements out there, I will find out when I need to.
    Now this is just me. I will take that gamble, and it's me that might pay. Everybody has their own comfort level, it's cool.
    #72
  13. Thumbs
    Thumbs Member
    Bath(ish)
    This used to be the case, like Made in Japan in the 50’s was, but presumably from making iPhone, etc they have got up to speed, I bought some to just check them out and they’re exact replicas
    I took my vernier micrometer to every component and they were all dimensionally correct, I didn’t check the jets though and also didn’t use them, I bought new #40 pilots from NPR
    #73
  14. squirrelman
    ^^^ big difference between electronics and hardware like the shitty steel they use in 90% of cheap crap harbor freight tools.
    #74
    Thumbs likes this.
  15. RogueRC24
    I did order a Keyster set of carb parts last year and they didn't match anything except the float bowl gasket.. really dissappointed.
    #75
  16. RogueRC24
    #76
  17. Thumbs
    Thumbs Member
    Bath(ish)
    Sorry that should be NRP https://nrp-carbs.co.uk/
    #77
    RogueRC24 likes this.
    Man, the U.K. sure has way more specific vendors and resources for carb parts than here in the States.
    That's a great lead Thumbs, thanks.
    #78
  19. Thumbs
    Thumbs Member
    Bath(ish)
    If there’s anything you want or think the shipping is excessive message me
    #79
  20. RogueRC24
    I just submitted an order from 6sigma for the jets only. 2 x 127 and 4 x #40. Lets see what I get in the mail.
    Do the needles usually have a washer spacer already installed. When I pulled the needle out of carb #4 it had a small washer spacer already on it. When Capt recommended .5mm washer, was that to be added to the already present washer or just a single washer spacer at .5mm? THanks!
    #80
