Thermostat Replacement
Discussion in 'Mechanics Garage' started by Action, Nov 4, 2007.
  1. chesthing
    chesthing New Member
    Colorado
    You don't want to do that - it will run rich and idle high for way too long. I can't believe what a huge pita Honda made this job!
  2. Rangerscott
    Rangerscott New Member
    Texas
    You need restriction for
    1. For the engine to warm up as fast as possible. The longer it takes, the longer it runs rich and damage can occur running an engine too cold.
    2. Restriction helps keep the coolant in the rads for a period of time so it can be cooled off. If there is just non-restricted flow the coolant will just fly through the rads and barely get cooled off. Thats why your bike will run super hot in the city, but is still able to keep cool on the highway. Also you'll notice it takes longer for the bike to cool down.
  3. cowboy
    cowboy New Member
    Athens, GA
    Thanks for a great job!!! I needed one as well, and was nervous when I got the air box off. Together Sam Adams and myself pulled it through. Thanks again for the pics and description. People like yall make the internet AWESOME and the dealership broke. Thanks again!
  4. Action
    Action New Member
    Albuquerque
    Glad the write-up helped. I feel the same way, it's better when you can at least see what you are getting in to.
    Action
  5. hondawolf
    hondawolf New Member
    Livermore, Ca
    Great write-up! Thanks again. I noticed mine is running as low as 145 degrees on the freeway at night, when it's in the 40's. Didn't realize they had it stuffed down in the middle, that sucks. Your write-up makes it look easy, though time consuming. Thanks again, guess I'll have something to do this weekend after all.
  6. drewl
    drewl Insider
    Virginia Beach, Va
    Thanks for the reference, Action. Just in time.
  7. drewl
    drewl Insider
    Virginia Beach, Va
    It is done. Thanks for the warning on the throttle body. That part sucked.
    Good write up. Saved me from having to do it.
  8. Action
    Action New Member
    Albuquerque
    Drewl - Glad you got her done. I know its a pain. I bled both brakes and the clutch today, not fun either.
    Action
  9. jetblack
    jetblack New Member
    Oklahoma
    That is the cleanest garage I've ever seen.
  10. Joey_Dude
    Joey_Dude Member
    North Georgia
    I replaced the thermostat as just preventative maintenance and I have to add one thing to watch out for is putting the throttle bodies back properly. If you don't push them in all the way down the rest of the parts won't fit. Maybe it was just me but just pushing down wouldn't cut it. I ended up getting a 4x4 wood block and lying it on the throttle body and pounding on the wood block with a hammer so it'd go down.
  11. ohsix9
    ohsix9 New Member
    I used a 180 degree thermostat out of a mid 90's 2.2l chevy cavalier. it doesn' t key into the housing exactly the same since it is centered not offset but if fits right in no cutting required. rotate it around and it will fit best in one spot and yes the internal spring clears and it opens fully. works beautiful total cost 12 bucks canadian.
  12. djmote78
    djmote78 New Member
    West Phoenix
    changing thermostat
    how hard did u have to pry i have a 98 and blew a hose coming off the theremostat housing to the cylinders, I cannot get those F@@@ers out for the life of me i used a larger screwdriver and a piece of wood and could not do it. i have 85,000 miles on it, is it just that hard to get off, Is there anything attached under them i cannot see?? thanks
  13. djmote78
    djmote78 New Member
    West Phoenix
  14. drewl
    drewl Insider
    Virginia Beach, Va
    It took a friend and I about 20 minutes to get the throttle bodies off. It helps if you pull straight up on all four corners.
    Good luck.
  15. Action
    Action New Member
    Albuquerque
    They are a bitch to get loose. Did you try putting some heat on them? I used a blow dryer.
    Action
  16. Silverado
    Silverado New Member
    Northern Dystopia
    Great write up! This is exactly the kind of info forum members do best.
  17. donald branscom
    donald branscom New Member
    Guerneville CA
    Really insane place to put a item that need s replacement from time to time.
    Very poor design.
    Honda really needs to get motorcycle people back into the motorcycle design dept.
  18. donald branscom
    Guerneville CA
    Love that avatar video joey.
    I would add one more step to that thermostat replacement if possible.
    I would try to get that thermostat housing outside of that hole and out of that space from under the fuel injection bodies. Could it go outside of that hole or is there something in the way?
    Here is the Kawasaki 1500 combo unit that includes filler neck,thermostat and bleed valve all in one. Best I have seen.
  19. NorcalBoy
    It was put there for a reason. It's not like the thermostat gets replaced like oil, coolant, or tires. It's my opinion that doing a bunch of work to move the thing around is attempting to fix something that isn't broken.
  20. donald branscom
    Guerneville CA
    Well having it located there is STUPID, and they could have least had the bolts facing UPWARDS so that you do not have to undo all the hoses,clamps and entire unit to get to the 2 bolts to change the thermostat. right?
    VF100R engine below:
