Throttle advice.
Discussion in '7th Generation 2010-Present' started by Mr.hifi, May 28, 2021.
  1. Mr.hifi
    Mr.hifi New Member
    Hello Guys, Help needed.
    After spending 3 years with my beloved vfr 1200 2011 model, My wrist/throttle control has evolved to extreme soft/sensitiv wrist skills :)
    My biggest problem is of/on throttle in different rpm/gear/speed situations.
    (But not in all riding situations)
    Lets say im in 3 gear and go completly of the throttle and try carefully to open the throttle,
    Then it feels like its impossible to do a smooth opening without using the clutch...off / 5 % on...
    (Not in all rpm/gear/speed situations)
    but in some different rpm/gear/speed situations.
    The Sabsteef remote online
    ecu reflash/firmware, did improve alot on these throttle issues, and 60 % of honda limitations in first gear is gone and 80 % in second gear... "Huge improvment"
    But stil a pain in the arse with the throttle response in some situations... "leftovers"
    im wondering if the throttle position sensors is out of sync ?
    Or maybe changing the oem-valve exhaust system, causes fuelling/throttle problems ?
    I have not ridden the 1200 with stock exhaust,
    so nothing to compare against.
    (Scorpion Factory carbon/ without DB killer)
    The bike pulls like a train and last dyno says 162 bhp at the wheel...131 nm in fifth gear.
    Despite the throttle issues,
    the vfr 1200f is a keeper, yesterday i ordered Wilbur 640 rear suspension
    And the new yss 10,5 nm linear fork springs was a gamechanger ! Even with stock valves !
    Sag is spot on, And Big red is now fantastic on bumpy Roads at high speed...look forward to see how the Wilbur 640 rear shock performs.
    Honda VFR 1200 f 2011.
    40.000 km.
    Exhaust. Scorpion Factory carbon.
    Airfilter. Stock/oem.
    Spark plugs. Ngk iridium
    Shell V power oktan 100.
    Kind regards from Denmark.
  2. Mr.hifi
    Mr.hifi New Member
    EDIT...
    DB killer Back in big reds scorpion exhaust...
    (First time)
    Throttle control is much better now, and i can hear birds singing
    No doubt that the VFR 1200 engine/throttle by wire, is extremly sensitiv with Air/fuel mixture !
    I think the VFR 1200 gonna need a PC5 to run smooth, if the stock valve exhaust is replaced
    with OPEN CAN exhaust....
  3. Diving Pete
    Diving Pete Insider
