Tiger Tiger
Discussion in 'Anything Goes' started by drewl, Nov 14, 2008.
  1. btay67
    btay67 New Member
    Peculiar, Mo
    First question is if we are dealing with a 5th gen flux capacitor or a 6th gen flux capacitor because there is a difference in the connections and how the feel....
    yeah the 5th gen is more visceral according to the 5th gen owners here, but there are ways around that. although it is hard to breathe in there, you can always use a gsxr airbox with a cbr 1000 swingarm....but you have to rejet your power commander if you do.
  3. drewl
    drewl Insider
    Virginia Beach, Va
    I believe you may be missing the point here, folks. This is not entirely about the capacity for rationalization. These things can be replicated among several genre. Two or three simultaneously. I have personally done it at least 4 times in the last 10 years. The key point to recall is the refractory period requires potassium. The ion pump must not be interrupted.
  4. drewl
    drewl Insider
    Virginia Beach, Va
    OK, let me put it another way...
    It is much like walking under a motion sensor flood light. You see?
    The first step activates the switch allowing electricity to flow to the bulb.
    Once the bulb is lit, the rest is elementary. Click click. So just then I notice that nitro is mixed in D5-sugar water, if you will. So i am standing in 500 cc of sticky liquid death(again, true story). Needless to say, I was pissed.
  5. NorcalBoy
    That is something I had not thought about......so what you are saying is, delinking your ion thingy allows your vfr to be a cartoonish impression of an RC212V? I need the schematic for that. and where do i buy the tools? can you rent them?
  6. crustyrider
    crustyrider New Member
    North Country, New York
    yeah, but if the gyro isn't sync'd to the rotary drive the slagal motor won't pump correctly?
  7. 34468 Randy
    Earthworms
  8. NorcalBoy
    As long as the voltage output doesn't drop when you turn the key off, it should work just fine, but if it does, you are in desperate need of a carb cleaning, or maybe just a synch.
  9. NorcalBoy
    wow, thanks, this site is uber helpful.
  10. NorcalBoy
    this might be the thread that exposes the complete ridiculousness of running with scissors.
  11. drewl
    drewl Insider
    Virginia Beach, Va
    Crusty raises a valid point. by substituting one for the other, it widens the array exponentially.
    Norcal, on the other hand, raises an argument that cannot be discounted. Time and time again I find myself faced with this puzzle in my daily life.
    I have experimented with the natural oils(as described in another thread). But in this application, I cannot say I have come to the same conclusion. So the experiment continued.
    The logical next step, as you all know already, was street grade methamphetamines.
    One must be careful while in this vein, no?
  12. NorcalBoy
    i was going to post up a link to a site about that, but they went out of business...it's now jailbait.com, WTF?
  13. drewl
    drewl Insider
    Virginia Beach, Va
    How can you bring up skeletons at a time like this?
    Listen. The felt on a pool table has to be exactly the same thickness across the surface, right?
    RIGHT?!
  14. drewl
    drewl Insider
    Virginia Beach, Va
    To be completely fair, I must remove myself from this discussion and rest. I will return when I have a fresh point of view.
  15. NorcalBoy
    I look forward to your fully rested opinion.
  16. RVFR
    Whew! and here I thought I was going to have to send in the Calvary to save said 5th gens dialectics. I heard the weight savings on a 520 conversion will speed up the slick 50 compound as to make the syncing of the FI go smoother, making all 4th gens the better choice.
    Tiger Tiger
    in the night,
    pray no more,
    till you see the light.
  17. crustyrider
    I disagree, the plumeage on the ostrich DO NOT, I repeat, DO NOT look as fancy as the plumeage on the no extinct dodo bird wich by the way was run out of existance when the spaniards landed on the south american continents...but I digress. the colors that the two have don't even stand up next to the turkey.......
  18. crustyrider
    but I will conceed the point that you made about the Barred rock chicken being the fiercest in the coop.
  19. vfourbear
    vfourbear New Member
    Cincinnati
    I'm sick of this, Its obvious people that a simple statistical model using the Planck-Boorman method will pick up all outliers and avoid us having to just " pick a winner'.....
    OBVIOUS......
    Without the data firmly in hand, it's impossible to convince midgets to sync your carbs, much less convince them to wear the proper gear
    I'd stake Drewl's reputaton on it, and I feel Norcal fully supports our decision.......now I too must rest
    I'll post the proper link when I feel the time has come to do so. And of course I apologize if my tone seems harsh, I'm just trying to state the facts here,
  20. realnew
    realnew New Member
    Moved to Toronto
    my wife read this and said i should stick to the porn sites
