Tink's annual project - T3
Discussion in 'General VFR Discussions' started by tinkerinWstuff, Oct 7, 2011.
What to do with T3?
Poll closed Jan 5, 2012.
  1. 3rd Gen FI
    5.9%
  2. Powerplant transplant
    23.5%
  3. Meet in the street - let's fight!
    35.3%
  4. I like it dirty
    35.3%
  1. tinkerinWstuff
    almost 9hours later and you still got nothin?
    Shame, I expected more from you.
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    If the bike is already leaking fluid you should just convert it into a Harley.
    Rollin
  3. tinkerinWstuff
    It's not leaking any fluid :confused:
  4. Singer732
    Singer732 New Member
    Rancho Cordova (Sacramento), CA
    Build the Street fighter! We have cafe racers a plenty and Toe amazed us with the tech wizardry. It's time for some thing Brutal yet refined. There should be lots of good engineering problems to be solved in opening up the V4, and some clever work on the front end would be interesting.
    Something that makes lesser men pale and women go weak at the knees or vice versa.
    :cool::cool::cool::cool:
  5. ridervfr
    Body is'nt even cold yet and the VULTURES are circleing :tongue:
  6. tinkerinWstuff
    the ugly remove
    I guess I should have considered an option #5; keep scavenging salvage parts until she's restored to a normal 5th gen
    subframe, rear shock, seat, tank, tail plastics, fairing stay, bars, forks, dash, windscreen, tail pipe & can, probably more. Easy $1500 in parts before paint (some plastics I have would have to be welded) many many hours
  7. TOE CUTTER
    That sounds like a real option, it is real good shape. I have a yellow upper you can have that is not bad at all.
  8. tinkerinWstuff
    yellow is my favorite
  9. reg71
    Sikeston, MO
    Are the rims and frame polished?
  10. tinkerinWstuff
    the rear wheel is polished. Not sure that it's my favorite.
  11. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    Well, if you want to go back to 5th gen, but do something different/custom-ish, I have a 6th gen subframe and tail plastic. If you dont want to go that route and need an exhaust, I still have my gen5 jardine can and mid pipe waiting to find a home.
  12. tinkerinWstuff
    well there's a neat concept BWeiss. That would require custom exhaust and custom seat. I'll need to decide if I want to build this for myself with the intention of keeping it or if it makes more sense to restore it on the cheap to OEM and make a dime.... Decisions, decisions...
  13. BWeiss
    Rancho Cordova, Ca
    Well, just let me know what you decide, they've got your name on it if you want them. Just taking up space in my storage, and then the future garage.
    You wouldn't have to do much for the custom exhaust. 5G and 6G exhausts are nearly identical with respect to how they collect and where they exit the bike from underneath. Infact, a popular 6G mod is to replace the stock headers with 98-99 headers.
  14. slowbird
    slowbird Member
    Toronto, Ontario.
    Anything but a streetfighter. Done too often IMO.
    also a fan of the BMW F800GS (as well as the tiger 800)
    The idea of putting it back togther is a good one. Even doing what BWeiss suggests...maybe a VFR generation 5.5 build?
  15. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Please PLEASE don't fighter that girl, 5th gen's are tooo pretty.:popcorn:
  16. tinkerinWstuff
    no worries, I just don't think fighter is my style. I'd rather tour the long back state roads of a 4-500 mile day or explore the dirty mountain passes. Terrorizing the neighborhood on a SF isn't my style.
    Bweiss could be on to something. A 6gen tail with 5th gen front and a custom seat to tie it together. That could possibly be done without looking like a complete abortion.
  17. Fazer1Sniper
    Fazer1Sniper New Member
    GO Crazy....
    Body and tail swap with modern inverted forks.
  18. tinkerinWstuff
    Love the modern and robust look of the inverted forks. Have wanted to do a retrofit for some time. However, I spoke to the local suspension guy and he didn't recommend it. His statement was to the affect that the forks and the frame are designed to work together. If you remove the flex from the forks but the frame wasn't designed for it, then you can have adverse affects in handling and durability.
    Not sure that I ride well enough to know the difference. Clearly the same issue would be present had I decided to throw MX forks on the front and make it a crossrunner. I'll have to speak with the suspension guy about this some more.
  19. reg71
    Sikeston, MO
    I've always liked the bioblade, but it doesn't quite mesh together as nicely as a factory bike. not bitching mind you. it looks very nice. I even like what they did with the front. it's just something about the seat/tank/subframe area...
  20. Fazer1Sniper
    All true, both the tail mods and Suzuki forks I did on the gen 3 took alot of fabrication but I ended up happy with it. Not that there is anything WRONG with restoring a gen 5 stock, awesome bike, just a great opertunity to build something one off and special.
    .... side note, the rapidly aging gen 3 body in Her bike MAY be getting swapped out for some other body this winter, not nessisarily Honda. It's just so old and cracked up that getting taken off and on and off again is taken it's toll. Let alone the drops.
