Tool to Remove Stuck Oil Filter
Discussion in 'Mechanics Garage' started by ewryly, Dec 27, 2009.
  1. betarace
    betarace New Member
    Middleburg, VA
    not to thread jack, but I use K&N filters ($7 on sale at Amazon from time/time). They have a 17mm lug on them that allows you to use a regular socket. The lug has a hole drilled for those of you that safety wire. Comes pre-lubed. All good
  2. Keager
    Keager Member
    I was luck enough to snag an oil change wrench that is about 1/8" thick unbendable wire that is quite small, almost like pliers with a ring for the filter. Worked great on my CBR, not quite so well on the Viffer. Still, it is an ease getting it in & out.
    After the first oil change myself (1.5 hrs) I decided to take it to a local shop instead.
  3. 34468 Randy
    We are supposed to change the filter too WTF
  4. ilovheros
    ilovheros New Member
    Cincinnati
    Bro, this is the way to do the SCREW- driver thing if you/ I do it!
    TX
  5. plasma
    plasma New Member
    Merseyside England
    Plasma.
  6. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    +1, same here, too bad they charge triple for that little damn nut. Not to sound like a know it all but oil is the WRONG way to go for lubing the oil filter gasket IMO. Oil seems to act more like glue than a lubricant once it is heat cycled enough times, however, an nice thin coat of wheel bearing grease is a wonderful thing. Just my 2 cents.
  7. tinkerinWstuff
    I have one similar to this except it has it's own handle. I think it was the first tool my dad ever handed down to me as a teenager.
  8. 34468 Randy
    I think it was the first tool my dad ever handed down to me as a teenager.[/QUOTE]
    Did you take the hint?
  9. dizzy
    dizzy New Member
    MN
    As a full time line tech for 25 years...meaning my oil changes have been in the thousands...I have to disagree with you 'hand tighten' guys. It's not at all unusual to see oil leaks at filters and in almost every case it's because they weren't adequately tightened. Much worse, I've seen filters loosen enough to spit oil on rear tires. Matter of fact I can think of two accidents and one oil starved engine over the years caused by this very thing.
    If oil filters are torqued to factory specs and you have a decent removal tool they come off just fine.
    On occasions when I've had filters that were 'problem children'...if a large channel locks doesn't do it or won't fit, I use the technique described by winaje...except I use a cold chisel and a dead blow hammer. It also helps to alternate blows 180 degrees apart on the filter. I can't remember spending more than 5 minutes to remove even the most stuck filter...at least since I was just a novice. Pounding a screwdrive through the filter to use as a handle is messy and it doesn't work worth a darn.
  10. Badbilly
    How dare you even suggest to some of these guys who have changed thier oil as many as three times,have 200 motorcycles 9 computers and have 225mph VFR's that get 60MPG that they are doing it wrong. Such nerve!!
    :director:
  11. ilovheros
    Cincinnati
    I have changed my fair share of oil in cars and bikes but i for one did learn a few new things from this thread. Hura!
  12. ilovheros
    Cincinnati
    This was one that i will try next time.
  13. Badbilly
    I had a filter once that was so stuck that I had to get a buddy who is a fireman to borrow the Jaws of Life from his fire station. Has anyone tried a cutting torch or one of those small Makita saws?
  14. vf750j
    vf750j New Member
    Calgary
    These pliers (link) or surgical gloves (for grip) have never failed to do the job for me when all else fails. Impaling the filter with a screw driver is not a good option in my opinion.
