Total System Failure
Discussion in 'Mechanics Garage' started by 00viffer, Aug 6, 2012.
  1. 00viffer
    00viffer New Member
    Harrisville Rhode Island
    OK while it may not be catastrophic, i do indeed have a failure of some yet to be determined component. I was told by a shop that the reason why my headlights were dimming and my gauges resetting was because of the HID kit i installed. It draws 8 amps of power per ballast. Anyway, i tear the bike down and put the stock H4 bulbs back in. Button the whole bike back up and start it. It runs for 5 seconds then died. I was like OK maybe it was just the battery being low. I start it back up and rev it to 5k to charge it. All of a sudden the bike just stops running. Cold. Dead. i try to start it back up i get nothing at all. no clicks no gauges no lights, nothing. by the way this is a 2000 vfr. with the key off the clock comes on but thats it. As soon as i turn the key to on the clock dies and i have nothing. Clock just resets after that. Any idea what it could be before i completely strip down the bike to follow the power wire though the whole bike? thanks in advanced! any suggestions help, except take it to the shop.
  2. TOE CUTTER
    Charge the battery fully and put a meter on the charging system and check performance. Step one. HID is not your issue.
  3. Scubalong
    Have you check to make sure to test the R/R and the stator to see if they are in working order. This symptoms sound like it especially for the 5th gen.
  4. Scubalong
    Toe is correct HID light is not the issue. Many of us run with HID for years without any problem.
  5. skimad4x4
    France
    French Alps & London
    For testing advice search for recent posts by Rubo. Also check the fuse beside the battery is OK, and look for signs of melted wires or connectors on the charging circuit. Almost daily there have been reports on here of vfrs with electrical problems affecting bikes up to and including the early 6th Gen models and it seems you are just the latest. I doubt the HIDs caused the problem.
    Skimad4x4
    Proud Member 6th Gen Militia # 218 - European 1st Division
  6. Ghost
    Ghost New Member
    Kernersville, NC
    Winner Winner, Chicken Dinner.
  7. tinkerinWstuff
    5th gen VFR, dimming lights, then no running at all.....
    If the battery had enough charge to crank the bike, it would have enough power to run for a little while.
    agreed with quick inspection of battery and charging with volt meter - however my money says:
    check orange ground connector taped up with the electrical harness on the left side of the bike.
    I'm really not sure based on the information given so far - just thought I'd throw something different out there.
  8. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    My 5th gen started dying on deceleration, luckily close to home. It would refire, but then die again next slow down. I checked the wires to the RR and they weren't burnt. Not having a tester and knowing the battery was several years old, in went a new one, about 2000 miles later and all is good still...
  9. Ghost
    Ghost New Member
    Kernersville, NC
    hmmm, Tink appears to be TOTB
    Smart move.
  10. tinkerinWstuff
    I am not too old to bang - chicks still dig me
  11. silverbullet132
    silverbullet132 New Member
    Check the relay behind the battery on the left side of the bike. I had the EXACT same problem as you, and it turned out this relay + two fuses were blown.
  12. squirrelman
    Sure enuff: that starter relay plug is always a suspect in cases of electrical chaos.
  13. silverbullet132
    Especially since all power has to go through it before it reaches the rest of the harness.
    Sent from my MB860 using Tapatalk 2
  14. tinkerinWstuff
    Assuming you subscribe to conventional theory as opposed to electron theory
    Electron Theory
  15. 00viffer
    00viffer New Member
    Ok so I pulled all the fairings off last weekend, sorry I wasn't around to check replies I was busy getting my car inspected. That was a nightmare in itself so I didn't have time to tinker with the Viffer. Anyways, pulled every single fairings off and loosened the tank. I reconnected the battery, and yes I did test with the battery connected to start with. That's how I figured out that I still did have power at the starter relay both before and after so it wasn't the relay. Every single fuse was pulled and checked and put back. I still had nothing at this point and this was prior to pulling the nose and side fairings off.sorry if this is confusing. I tested Everything before I pulled the side and front fairings. I pulled them last weekend and was going to show my friend what I was working with. So I put the key in, and I had the clock. This was normal at this point. I go to crank her over and the beast roared to life! She was magically fixed and running! I couldn't believe it. Literally the only thing I did was pull the side and front fairings off. I didn't do or touch anything else. I didn't replace any fuses or relays or check connectors. So needless to say I'm excited to be able to ride again. I just have to put it back together. I'm going to turn it on after every individual fairing goes on just to make sure its not pinching a wire and grounding out. I appreciate all the help though, I guess she was just tired.
    New problem. Should I run a relay for the HIDs? Would that help me out? I shouldn't even be asking because I install them on so many things that I should know better. It's just a strange coincidence that I had the bike die after installing them. To all of you running them are they just the normal 35w setup? If so how many amps ( measured) are they drawing and how many amps do 45w and 55w halogens run? I had an independent shop tell me the HIDs are going to kill my bike. That it was going to pull too much power and that's why when the bike returned to idle my gauge cluster would freak out and act as though it just turned on.
  16. tinkerinWstuff
    Classic symptom of a bad connection at the orange ground connection. That bike will leave you walking somewhere if you do not check that thing. All I has to do is get hot from current draw and exhaust heat then you'll find yourself miles from anywhere hoofin it in motorcycle boots.
    Things don't fix themselves and you need to find the cause. Dollars to Jo-jos that it's a burned connection at the orange plug and your tugging on wires temporarilly restored the connection.
  17. 00viffer
    00viffer New Member
    I will have to check it when I get home. So its left side of bike? I didn't see anything Orange when I was putting it back together. What's it connect to?
  18. 00viffer
    00viffer New Member
    What kind of repair would it be? A new connector or would it just need a good cleaning?
  19. silverbullet132
    The repair I did on mine was solder 2 wires from it directly to the main frame ground, it is in the harness near the R/R on the left side of the bike.
  20. tinkerinWstuff
    Pretty sure I showed a photo of it and the location above.
