transmission question
Discussion in '3rd & 4th Generation 1990-1997' started by matt1986vf500f, Jan 18, 2011.
  1. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    Buddy of mine is going to look at a 94 vfr but the.guy told him the bike has a shifting problem goes into first and second no problem but wont go into any other gear I guess what could be the worse case scenario.
  2. TOE CUTTER
    Shift drum would be pretty piss poor. Had a gen1 with that very same issue and cracked drum was the problem.
  3. squirrelman
    Also could be bent shift forks possibly maybe ? Cani't rule it out, can ye , eh ?
    Any excessive forcing of the lever during gear change or trying to shift while rear wheel is not rotating a little can cause damage to shift forks. Slots need to align with slots in the gear selectors, and only some rotation of front sprocket or rear wheel can line up shafts.
    Otherwise......... risk damage, nasty clunks, loud bangs, chipped teeth on gears, which will only get worse.
    If it won't get the gears while the front sprocket is turning, you might need a full teardown to fix it + $$$ part$$$+ a close contact with an internet "discount" parts supplier on line.
    Try ONE hard ride on a gen 4, Matt, and tell us what you think; you think it might just light years ahead of the design parameters of ANY VF series.
    The gen 4 just might be the apathiosis of VFRdom, after you ridden one hard, IMO. Who needs VTEC ? "Last of the carbed VFRs" is a landmark in and of itself. Having no cam chain tensioners is an incalucable benefit cuz Hoinda never got it right.
    Best balance between power, tire width, suspension, weight. OK, no R6 or R1, but this bike is capable of doing more than you can uinless you're Freddy Spencer.
    Fast road bike but a little fat, but fatties can be fun doncha tink ?
  4. matt1986vf500f
    If I could find a forth gen for the right price I would think about it. But my fifth gen does me just fine. But to tell the truth the 500 would run circles around he 800 in the mountains.
  5. matt1986vf500f
    So I should tell him to pass on this one? .
  6. crustyrider
    crustyrider New Member
    North Country, New York
    if he is a wrench turner , and the price is under 1000 I would say buy it and repair it...if not take a pass
  7. tinkerinWstuff
    Unless somehow there's something funny with the ratchet mechanism, it's a case split to fix. Basically a complete engine overhaul.
    Pass unless he needs it for a parts bike.
    A pristine 4th gen in mint working order is only worth $2400 max
  8. TOE CUTTER
    If clean and a VERY good price I would jump on it but I doubt that is the case.
  9. matt1986vf500f
    Its in decent shape it won't wow you and the price is ok but if I was buying I would go down at least 500 bucks more.
  10. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Matt:
    What about my 4th gen for sale? No transmission issues :)
    BZ
  11. matt1986vf500f
    Your bike is for sale!? Dude why?
  12. tinkerinWstuff
  13. Bubba Zanetti
    Delaware
    Thanks Tink for posting up a link to the sale thread on your post.
    Matt, check out the link and see if your friend would be interested. I can trailer it down a few states and meet someone in the middle for pick up.
    Why am I selling? A couple reasons, the main reason is to fund the purchase of a TZ125 I've been blessed with and the VFR is going to sit and the wife won't permit 3 bikes in the garage LOL! But with 2 kids I don't have time for 3 bikes anyway.
    BZ
  14. Heatmizr
    Heatmizr New Member
    Charlotte, NC
    I second Squirrelguy's comment on the last carb'ed VFR... The throttle response on my 4th gen was perfect. My 5th gen with FI is a small step backward, at least in that regard. The entire bike has never felt quite as "dialed in".
  15. matt1986vf500f
    ill tell him about bubba i just going to tell him to pass on this one that he's looking at.
