Turning mid-aged
Discussion in '5th Generation 1998-2001' started by vfrcapn, Mar 24, 2015.
  1. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Just thought I'd post a pic, '99's mileage end of commute today.
  2. NormK
    NormK New Member
    Good effort, do them all yourself?
  3. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    Impressive!
    I bet there were many stories along the way...
  4. Hondaman57
    Hondaman57 New Member
    Thailand
    Bangkok
    Nice. You have done more than most, is a way of putting it.
  5. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    97K of those miles were mine.
  6. V4toTour
    V4toTour New Member
    how many valve adjustments? if any
  7. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Did 16K, 32K and 48K valve checks. One valve out at 48K, let it go after that.
    Valvoline 10-40 dino it's entire life, oil changes every 3K at first then went to every 5K. And Fram oil filters most of the time, same K&N air filter for probably 75K.
  8. prelude222
    prelude222 New Member
    I just turned 40, me too
  9. NormK
    NormK New Member
    Good rap for the oil might even switch myself after hearing that
  10. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    What a great testament to man and machine. You done good!
  11. ridervfr
    Belgium
    Nice work! How many stators and r/r-z did you go through?
  12. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Original stator, and I swapped out the original r/r for the new Honda unit, just because, at around 25K 10 years ago. Few burnt connectors but no more problems after I soldered the wires together.
  13. NormK
    NormK New Member
    Proof in the pudding, a new saying we should have here, "soldered wires saves you dollars" because unless you bang it into people that soldering will save dollars they continue to go on about wanting to use connectors of some sort so it is easy to change it over in the future, if it is soldered you don't have to change it, but if you do it is only a few minute job in the scheme of things because you are broken down anyway. Fitting a volt meter lets you monitor the charging all the time you are riding and gives you a bit of warning if things aren't happy
  14. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Only bad failure was 2nd gear going out around 95K. I swapped in a used motor for now and planning to rebuild the original transmission and maybe motor, & put the original back in when I can find the motivation. Says something you can pay $300 for a used 800 V4 motor from a wrecker and just drop it in and run it.
  15. 2wheelrush
    2wheelrush New Member
    kewaunee wi usa
    Nice. I stopped on the side of the highway on the way home to take a pic when my 05 concourse rolled over to 100,000 miles. After 6 & half years of riding it?:cool:
  16. ridervfr
    Belgium
    2nd gear huh, you were drag racing from the traffic lights :lol: My 91 seems to be stuck at 80,000 miles as it gets its yearly oil change and ridden maybe once every one or two weeks. I would take a picture too of the odometer :smile:
    Yeh parts are cheap huh, good deal. Amazing what you can get/do.
