Tyre prssures when heavily loaded
Discussion in 'Mechanics Garage' started by J800VFR, Feb 27, 2021.
  1. J800VFR
    J800VFR New Member
    East Grinstead, WEstSussex
    Hi,
    I'm looking for advice on what tyre presures I should be running when loaded up with either a pillion or a similar weight of camping gear, circa 65Kg.
    I've a fully adjustable Ohlins monoshock with remote preload knob so that's quite easy to change.
    My bike is a VFR800 FiX (1999/2000) running T31 Brisgestone tyres.
  2. fink
    fink Member
    Manufacturers state 36f 42r regardless. Only bmw as far as I know offer different pressures for load conditions.
  3. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Loaded to the max, I would run 40 psi front, 42 psi rear. That's assuming you'll be a little less
    enthusiastic on curvy roads.
  4. raYzerman
    raYzerman Member
    Millgrove, ON
    Agree with 40/42..... 36 isn't enough to me regardless of passenger or not. However, pick the front pressure based on how the bike handles... 38 might be OK.
  5. fink
    fink Member
    40 in the front EEK
  6. Diving Pete
    depends on how loaded you are... I'd run 40 if was carrying 500ibs....
