Using the gears to help slow to a stop
Discussion in 'General VFR Discussions' started by suse, Mar 24, 2012.
  1. NorcalBoy
    thank someone, it's about time someone used some common sense. If ya don't want the kid to ride your bike, have your wife create an excuse, sheesh.
  2. 34468 Randy
    yeouch baby ! ! ! !
  3. DaHose
    DaHose New Member
    Napa, CA.
    I'm another rider on the downshifting bandwagon. I've always used engine compression and keep the gearbox engaged until I am coming to that final, full stop. I LOVE the very positive feel of the gearbox on my viffer and downshift on autopilot with a blip. I often can't remember/tell if I used my clutch during the downshift.
    One thing I read about (and remember to do religiously) is that if you are waiting at a light by yourself, do not idle in neutral. You gotta be able to get out of the way quick. If I end up with a couple of cars stopped behind me, I might go to neutral.
    Jose
  4. suse
    suse New Member
    Nampa, Idaho
    Wow the consensus seems to be with downshifting and using engine braking. I usually just go from say 6th to 4th without letting out the clutch. Then work through the gears with the clutch still pulled as I start to slow down. More or less coasting while working through the gears without letting the clutch out. I guess I'm the one who has been doing it wrong.
  5. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Nah, just thinking differently. :biggrin:
  6. Spike
    Spike New Member
    Not really wrong, just different. From what you said, you are assuring you are in the right gear, not just leaving it in say sixth, so you are able to scoot out of the way if you have to -- although releasing the cluth would ensure you are in gear, not a false nuetral or something. Also using some engine braking keeps you from overheating the pads and fluid -- which isn't really a HUGE problem anymore anyway. As long as you are matching the gear to the current speed, you are not abusing the engine or tranny.
  7. betarace
    betarace New Member
    Middleburg, VA
    The engine is not a brake. You dudes need to read Twist of the Wrist and get some training
