I was cleaning up my stack of V4 parts and noticed that the F2 heads are almost identical to F1. I have some damage on my F1 camshafts and I wanted to know if anyone attempted to fit F2 heads into F1 engine. Same for the oil pump - I have two pumps and two oil pans. Looks like a bolt on upgrade with nice OEM oil cooler setup. Any information appreciated. I will be tearing down my F1 soon to do the main bearings and crank bearings and I want to know your opinion.
Almost positive the oil pumps and pan are interchangeable. The chains needed to rotate the pump I am not sure of. I have had both vf1000f and vf1000f2 pans on my vf750f, they all work together nicely
"The chains needed to rotate the pump I am not sure of." What do you mean? I have F2 complete engine for parts with the F2 oil pump chain as well. Also I do not see any differences in the lower section of the engine (gearbox is different) so theoretically F2 engine should bolt on into F1 frame and some people claim they do not.
