VF1000R rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by hopit88, May 17, 2009.
  1. Mobtown
    Mobtown New Member
    Baltimore, MD
    *drool*
    If my bike ever looks half this good...
  2. supertex
    supertex New Member
    Hard to type this, and you understand how much I mean it. Very nice...... I am incredibly impressed with your taste and style.
  3. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Gorgeous, just gorgeous! Bike looks like it should have been made that way. Nice work all around. Interested in the head light. Can you actually see anything at night? Now go ride the wheels off of it and enjoy all the compliments your going to get.
  4. hopit88
    hopit88 New Member
    Thanks. Not sure about the headlight performance cause I haven't had it out at night yet. It does seem bright in the garage. It still needs a final aiming. It's a projector beam with an H9 bulb. It's only low beam but I would guess it's brighter than the stock bulb's low beam. I have a way to make it both H and L with an HID kit that has a movable shield for Hand L.
    I'm riding every chance I get. Temps are dropping here in New England but full leathers makes things toasty.
    I have a few things to address this spring. Unexplained high idle. New thermostat. Fix the fast blinking signals(LED's blink fast for some reason). Rebuild the RC51 front master. Find a CBR1000rr clutch master. Get or make a clear wind shield. Add some foam to the front of the seat, next to the tank. Wax it. Start riding the snot out of it.
    If the last point happens first, the others may not happen at all.
  5. tinkerinWstuff
    that was my problem. on my 3rd gen restoration I started riding the snot out of it and still haven't finished the decals and clearcoat like I intended.
  6. hopit88
    hopit88 New Member
    Ha! You should see all the 95% completed projects in my house! I just can't get to that last 5%.
  7. tinkerinWstuff
    likewise. If I refinished a room, everything would be done except the trim sitting in a pile for 3 years.
    But now I'm married so I don't know if I'll be able to get away with that any more.
  8. mikelaubach
    mikelaubach New Member
    Electrics keep you going. ;-)
    The LEDs require a special electronic flasher. The mechanical flasher for the stock setup relies on the resistance of the bulbs to trigger it at the proper rate, and the resistance of the LEDs isn't there. That is an easy fix.
    The high idle could easily be a vacuum leak at the carb isolators if the carbs are properly set up. Crack open a propane plumber's torch (unlit) and run the end around slowly until the idle changes - that is where the leak is. Do this outside obviously. ;)
    Don't wax it until the solvents have had plenty of time to outgas. The old rule was 6 months. I still use the old rule. If you wax too soon, you trap the solvents in the paint, and you will get tiny bubbles from "solvent pop."
    --MIKE--
  9. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I've heard that you can add a resistor in series with the signals. Do you know if that is true?
  10. hopit88
    hopit88 New Member
    Yep, Rad Shack has them, I forget the numbers. The web has a ton of articles.
  11. VT Viffer
    VT Viffer New Member
    South Carolina
    There are resistor kits at my local AutoZone, too.
  12. FoothillRyder
    FoothillRyder New Member
    Sierra Foothills
    Freakin' beautiful lad, just a gorgeous bike. Well worth all the effort.
  13. hopit88
    hopit88 New Member
    Thanks. Enjoy the new bike and be sure to post up some pics. Looking forward to seeing it.
  14. Outlawz24
    Outlawz24 New Member
    Lloydminster Sask
    Awesome bike man! What is the swing arm off of and how difficult was it to fit to your bike? Just wondering since the 1KR chassis looks like its based off of the VF750 chassis so i'm wondering if it is possible to mount the same arm on my bike.
  15. captb
    captb New Member
    Very cool, nicely done, lots of work!
  16. hopit88
    hopit88 New Member
    Thanks. The swingarm is from a '91 VFR. It's not that it's prohibitively difficult to do, it's just that there are so many other systems to move, trim, machine, fabricate, or otherwise fool with that you must have all your ducks in a row to pull it off and do so safely. The arm itself is tricky and you need a machinist to do some parts but you also have to make a completely custom exhaust because the arm passes through where the rear pipes come down. Then there's shock placement and linkages. Battery, puke bottle, fuel pump and wiring relocation, modifications to the frame...The list goes on forever.
    Thanks.
  17. Mohawk
    Mohawk New Member
    Bristol
    Absolutely beautiful build man, that puts my VFR800 refresh to shame. Now if only I'd seen this sooner :cool:
    Sweet ride, enjoy the summer.
  18. Outlawz24
    Lloydminster Sask
    Hmmm Thanks for the info! Def something to give some thought to. I have a spare chassis from an '83 VF750F that has no engine that i may need to experiment on :vtr2:
    P.S. hopit88 can you please clear out your pms? I tried to send you a pm about this and got a warning saying your pm box was full lol
  19. hopit88
    hopit88 New Member
    Thanks, you too!
    Thanks for the heads up. My in box is empty now.
  20. Outlawz24
    Lloydminster Sask
    No problem man. Got the same warning though for some reason.
