VF1000R rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by hopit88, May 17, 2009.
  1. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    The water pump o-ring seal??? I was looking for one of those a few weeks ago! Nice find..unobtanium now I guess!
  2. sanlot17
    sanlot17 New Member
    OH-IO
    I can give the numbers of the other places that suppose to have them. Lmk
  3. hopit88
    hopit88 New Member
  4. sanlot17
    sanlot17 New Member
    OH-IO
    This is my alltime fav bike. If I would ever do what your doing to yours this is the color scheem I would pick.
    dang! Didn't work on my iPod. When I get home I'll post it. Doh!
  5. sanlot17
    sanlot17 New Member
    OH-IO
    Here we go. I hope this works
    This is cool to. I think it's the V4 860 something?
  6. hopit88
    hopit88 New Member
    Mine will be very,VERY, close to this.
  7. invisible cities
    invisible cities New Member
    new york
    Cat is out of the bag!
    Color scheme looks spot on.
  8. hopit88
    hopit88 New Member
    oops.....!
  9. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    That is going to be nice.
  10. rc24rc51
    rc24rc51 New Member
    Liberty SC
    I have one on e- bay right now.
  11. VF1000RS
    VF1000RS New Member
    Colorado Springs, Colorado
    Going to look very cool I think.
  12. hopit88
    hopit88 New Member
    Baby steps part 2...
    Got the foot pegs on
    Hawk rear brake res. installed.
    Rear rotor, caliper, bracket and arm painted/baked/installed.
    Swingarm sanded and painted/installed.
    Carbon wrapped abbreviated rear fender installed.
    Lower rad. installed along with all hoses.
    Fuel pump relocated.
    Rear sprocket, cush drive installed.
    Misc. cleaning/detailing.
    Not looking so much like a VF1000R
    Small "shock shield" of plastic and Carbon.
    Swingarm sanded smooth and fresh paint.
  13. donald branscom
    donald branscom New Member
    Guerneville CA
    Beautiful bike and quality workmanship. Love your project !!!!
    Love those carbon fiber panels.
    I wish you could do a little tutorial on those. If you felt like it.
  14. hopit88
    hopit88 New Member
    Finished up the baffles this weekend. I'm using 22 gauge, 2.5" OD, perforated 409 stainless with 1/8" holes on 3/16" spacing. The 2.5" is the same diameter as the pipe so I had to make a slice on 2 sides and overlap each of the cuts. I then put on a hose clamp to degrease the OD down a bit. A few whacks and it seated down to the rivets, about an 1 1/2". Very, VERY snug fit. A few rivets hold it in place but probably overkill.
    At the other end, the cans end cap ID and the tube's OD are both 2.5". Again, a VERY snug fit. I cut the length to seat against the end cap. Once the cap is in place, all is rock solid. No concerns with movement once things heat up.
    No packing for now, I want to hear it like this first.
    Left side cut and in.
  15. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Were do you get perforate pipe at? I could use that stuff indifferent sizes.
  16. safetypro10
    safetypro10 New Member
    Dallas, TX
    OMG, no packing? Do the words "Deaf" mean anything to you? How about a spud?
    Larry
  17. slowbird
    slowbird Member
    Toronto, Ontario.
    Bike looks amazing.
    Make a video when you start it up please.
  18. donald branscom
    Guerneville CA
    It is not a pipe.
    Sheet metal.
    On my Vf 1000R chopper I used baffles with slip on tapered mufflers over. Sounded perfect.
    No "packing" to blow out all over the environment.
    H-D style baffle welded to 1-3/8 tube and inserted into the 1.5 inch tube header.
    View My Video
  19. donald branscom
    Guerneville CA
    Just because it has no "packing" does not mean it will be loud.
    Fiberglass packing just blows out very quickly anyway.
  20. invisible cities
    new york
    From what I read Hop is saying it is a perforated pipe...is this not correct?
    "I'm using 22 gauge, 2.5" OD, perforated 409 stainless with 1/8" holes on 3/16" spacing."
