vf500f (1986) petcock rebuild.
Discussion in '1st & 2nd Generation 1983-1989' started by beeton, Jul 9, 2018.
  1. beeton
    beeton New Member
    Sanded off all of the overspray from my gastank (previous owner liked to spray-bomb stuff it seems). Once together, I noticed a small amount of fuel leaking. Not alot but enough to eat holes into the asphalt. Tightened the vacuum-bypass lines (this petcock had been modded), all connections and although o.k for a few days, decided to leak again. I then noticed that the leak was from the side selector plate...the one riveted in-place... so off went the rivets and I see that it is a squared "o" ring. Surely, every hardware store will have one!
    My thoughts are:
    as the 86 runs off of a fuel pump and there is no gravity feed problem threatening to fill my crank case with gas, I could just j.b. weld the plate and selector in the "reserve" position and have the petcock in permanent "on" with a 2nd on-off fitting after the petcock and before the pump for service and safety. Any concerns I should know about? The other option would be to have a plate made to adapt the vfr 2 bolt plate connection to a more conventional petcock but that would probably cause the petcock on-off to sit lower than the stock one and I don't want a hole in the side of my tank. Would look stoooopid.
  2. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
  3. beeton
    beeton New Member
    Sadly, no. This is for the removable section of the petcock. The x ring is under the riveted section. I have never sen kits with that proper x ring. I may have a flange made and adapt to a screw-on version as that would make life simple BUT that would make the tank mounted control redundant.
