VF500F fuel tank vent
Discussion in 'Mechanics Garage' started by LDT, Aug 5, 2024.
  1. LDT
    LDT New Member
    Hi there. I'm new to this forum and this is my first post. I'm a proud owner of a new-to-me 1986 VF500F and currently going through sorting it mechanically.
    My question is about this nipple under the fuel tank. The bike has had PCV/charcoal canister, etc removed. Does this have something to do with that deleted system? Is there a hose that's supposed to be attached here at the tank?
    The previous owner left all the remaining holes un-plugged and I've gone through and capped all those (airbox,carbs,etc). This is the last one I can see may have belonged to a hose. Should I plug it?
    Thank you for any insight into this. It's been difficult finding images online or a diagram that shows this nipple. I also noticed not all years of the VF500F even have it. . as it may be a California thing.
    The gas caps on California bikes are not vented, so the tank must be to flow fuel. You do not want to plug that unless you have a vented cap. It originally was connected to the evap canister thru a vacuum activated valve.
    I would run a hose and route it down with the crankcase breather drain hose, as sometimes gas can dribble out of a vent spigot.
  3. LDT
    LDT New Member
    Fantastic. Thank you so much for the quick reply. I had plugged it but wasn't sure if my cap was vented or not. I will run a drain hose instead.
    Cheers to you!
