VF700F Carb Fiche or parts schematic
Discussion in 'Mechanics Garage' started by Dusthawk, Jun 23, 2009.
  1. Dusthawk
    Dusthawk New Member
    Okay, now that I got the parts bike, the carbs were in better condition than the ones I planned on putting in, and the Isolators were in much better condition. I spent all day today in 100+ degree sun removing from the parts bike and installing to the runner I want to ride.
    The carbs were a little stubborn but finally got them installed, everything after that went quickly, clutch hydraulic system went in without a hitch, and put every last bolt and nut in, save the tank hardware which I still need.
    I installed the battery but it didn't have enough power at first to even power the fuel pump, so it is still on the charger. I checked it about an hour ago and the fuel pump pressurized the fuel system quickly and perfectly, not a leak to be found anywhere.
    I have to trace the electronics though, my tail light indicator on the dash is lit and there are no brake or tail lights, so I hope it is as simple as a disconnected wire. Hope to have it running tomorrow. Will keep you all updated. Might even have pics of the first ride, lolol.
