Vfr 1000 Trans Fix
Discussion in 'Mechanics Garage' started by mrich12000, Jul 11, 2009.
  1. mrich12000
    mrich12000 New Member
    Calgary, Alberta.Canada
    As some of you know I have a VF1000k Euro unit . I had bought the bike knowing the 2nd gear was Not there. I rode the bike for over 1000 klms and then the 3rd gaer vanished too. So I came here and asked many knowlegable people what could be done ? Jamie D came forth and bestode a great deal of sanity unto me,Firt the thought of damaged shift forks, shift drum, ect.
    and the secret way to dismantle the lower half of the engine without taking off the heads ( So greatfull Jamie,) now Im here to post some pictures hope you like them as they show the secret removal..The big prblem was the shift drum Exploded on left & right sides were taken out I retreved all the bits, will show later I forgot it in my pickup as I went to show the main parts guy John at G&W cycle Calgary (Super Place),,
  2. mrich12000
    Few more pictures:thumbsup:
  3. mrich12000
    So now I Have received my clutch bucket tool from CMS Holland, so hard to find only 3 left. Now I have had the Left shift fork remade (it was cracked at the oil orifice hole)Had it miged and resurfaced. So now I am waiting for the mm shaft lock washer(I bought 3 u cant get anymore!!) This weekend I'm doing the carb, and gearing ready to paint the frame. should get her together my the middle af August. more to come ,pics to..
  4. skybucket
    skybucket New Member
    West Michigan
    Impressive
    Transmissions always scared me. Looking forward to updates.
  5. dietDrThunder
    dietDrThunder New Member
    Nashville, TN
    I'm with you. For me, a broken transmission always sends me to find another motor :)
  6. mrich12000
    Just waiting from Holland, for the elusive mm main shaft lock spacer then it full speed ahead, also ordering from Cycle Sonic of Kitchener, Ontario full carb rebuild kits. Good pric for these kit,I used them for my gold wing and the extensive replacement pieces were impressive . Pics to come Don't be scared to dismantle the engine it;s fun!!:crazy::thumbsup:
  7. mrich12000
    Now to rig the cam sliders into the proper place
  8. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Looking good. So what was the 'secret way' to removing the lower case w/out the heads?
  9. mrich12000
    Remove the two top right rear bolts (but don't take out of the case.)Now you have to loosen the cam chain support that is on the oil pump support rail, don't REMOVE IT! pull the cases apart @ 25 lbs pull. to put together, Fishing 16 pound stren and a fabricated nylon plastic 8 in long 1 in wide to place the cam chain guides onto the supports tighten the guide support now, making sure the shift forks slide into the gears. then drop the lower case back onto the upper case. (Engine is inverted ) Torque as per Honda works manual..
    Note the 28mm mainshaft washer is almost imposibe to find I found mine in Holland 's CMS and I bought them all...I have another motor to do for a bud..
  10. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    Thanks! :thumbsup:
    Does this work similarly for the R motor w/ the gear driven cams? Jamie?
  11. mrich12000
    Ye s even better no chains
