VFR 700 Carb disassembly issues
Discussion in 'Mechanics Garage' started by Wynnfreds.book.of.face, Apr 12, 2014.
  1. Wynnfreds.book.of.face
    Wynnfreds.book.of.face New Member
    Saint Joseph, Michigan, United States
    Hello, I recently got a VFR700 - the old owner told me I should clean the carbs - after taking the airbox off it turns out he wasn't lying. There was a rat/mouse nest in there (great) and thanks to the wonderful V configuration ratty was pissing directly into my carbs. Thanks to some of the corrosion that has happened in the bowl beneath the air filter, I can't get the 8 screws (with the retainers) out without seeming to strip the screws. I've blasted them with PB and still they won't budge - is there any trick to getting these out? I'd rather not buy a whole new carb - but if I did, would a VFR750 carb fit? I'm thinking maybe I'll have to dremmel the screws to fit a flat-head screwdriver but I'd rather not... Thanks in advance for your suggestions.
    Those screws need special care or heads will strip out. Gentle use of an impact driver, or hammering just a bit on the screw heads should help removal, loosens up corroded parts. Use quality tools. But it may NOT be necessary for you to seperate carb set from airbox just for a cleanup. Are throttle plates stuck ?
    I think we had a case here awhile back where rodent piss totally destroyed a set of carbs. 750 carbs from '86 or '87 will work on your bike.
  3. Wynnfreds.book.of.face
    Great I'll tap down on them and see - the throttle plates appear to be ceased but the vacuum piston/diaphragm and other parts seem to be in relatively good condition and not deteriorated - the jets turned purple though... Was ceased throttle plates the you had to ditch that set of carbs? Thanks for your response
  4. kennybobby
    kennybobby New Member
  5. ridervfr
    yep, never remove the carbs from that mounting plate! You can get a dainty pair of vise grips and have at the sides of the bowl screws if they are buggered up. Sometimes, this method is better than wacking on your stuff wit-a-hammer and assorted implements of destruction, thats just my "two-cents."
    We need pictures of rodents nests nestled in your carbeeZ! :worthless:
  6. TOE CUTTER
    I would make a lame attempt before ditching them but your gonna be better off with another set if they do not free up withoot getting :wacko:
  7. Dr. Jay
    Dr. Jay New Member
    Deland Florida
    With marginal philips head screws (I had some on my VF500 F just like yours) a dab of valve grinding compound into the screw head can keep the screwdriver from camming out. Also getting the Japaneese standard phillips head screwdriver might help since Japaneese phillips screws are somewhat different than US.
  8. squirrelman
    Set the carbs on each side for a few minutes and trickle your favorite lube down the throttle shafts, soaking for a few minutes and repeating as necessary. Try that first, along with whatever jets need cleaning.
  9. Wynnfreds.book.of.face
    Thanks guys - I actually bid on a carb on Ebay and got it for 35$ - I lucked out. For that guy who wants a picture of the carb with the rodents nest - here it is: rats nest vfr.jpg
  10. TOE CUTTER
    Oh my, that mouse took pride in his work.
  11. kennybobby
    Damn mouse bent your front brake lever too!
