VFR 700 in Florida
Discussion in '1st & 2nd Generation 1983-1989' started by sixdog, Dec 2, 2025.
  1. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    #41
  2. Bazza
    Bazza Member
    Just did a cold start video. Did not give her any throttle until well into the warm up stage. Which is how you're supposed to do it anyway.
    Seems to settle in at 1,200 RPMs. Gonna get a plate for her tomorrow and start riding her around a bit more before anymore fiddling with the idle.
    I'm still on cloud 9 to have scored such a good condition example with such little fanfare!
    #42
    Nice!!
    #43
    Bazza likes this.
    Need to find a tank "bra" to go with the lift-and-support front bra.
    #44
    Bazza likes this.
  5. Bazza
    Bazza Member
    Thanks! :)
    Ha ha - not much of a bra man so we'll see! :)
    #45
    We know...
    #46
  7. Bazza
    Bazza Member
    .....LOL......
    #47
  8. Bazza
    Bazza Member
    Quick update on this bike.
    Since last update I found and installed a proper Pearl Crescent White fuel tank for her - much better!
    This is also the bike that developed a problem with the starter motor clutch that fortunately was an easy fix.
    Thread:
    https://vfrworld.com/threads/starter-motor-clutch-repair-help.62854/
    And today, I swapped out the carbs with a rebuilt & synced set I had on the shelf from Joe Nelson/V4 Dreams. The reason I did this is the engine wasn't running smooth under any kind of acceleration and I figured it had to be clogged carb jets.
    I didn't want to mess with any carb cleaning today so just did the swap. I can clean the carbs now at my leisure. And it will only be the float bowls - nothing more needed! :)
    I still have to reinstall the windscreen after it gets the Novus treatment and finish up the lower fairing repairs, which are almost done. All that will be done this weekend.
    Video and a few pics......
    Carbs from Joe......ooooo.......ahhhhh......:D
    New carbs and air box installed and ready for a test with the fuel bottle!
    Fuel tank re-installed with new fuel lines and filter!
    MUCH better looking with the correct fuel tank!
    #48
    RogueRC24, Captain 80s and sixdog like this.
  9. squirrelman
    what, u dont clean ur own carbs ?? ppl send me carbs for cleaning occasionally, and i can them do just as well as as any joe and charge less 12-1-17_176.JPG.855a0e6828772e377747193f47761e4d.JPG
    #49
    Bazza likes this.
  10. Bazza
    Bazza Member
    I've never sent any out for cleaning. I do that myself.
    These were some I bought outright - all ready to go.
    It's not about the money - it's about supporting the V4 Dreams website - which has helped me more than words can convey.
    But I will keep you in mind if I need any additional help @squirrelman , I know you do good work! ;)
    #50
  11. squirrelman
    roger that good buddy :thumbs:
    #51
    Bazza likes this.
  12. Bazza
    Bazza Member
    Didn't get the fairings back on today but will tomorrow.
    Had to replace one of the front lower brackets which was not only missing - the ABS it attaches to was also missing. Both lower fairings needed quite a bit of patching but they should be OK now, hopefully.
    This is before I cut off the rivet legs.....
    #52
    RogueRC24 likes this.
  13. Bazza
    Bazza Member
    Making progress on the fairing reinstall. The lowers are back on but some unexpected rain interrupted the operation, for now. I only need to slide the hairpins in at the front bottom and then attach the battery covers. Then the windscreen, which still hasn't been cleaned....but is soaking with wet towels over them.
    I did some additional work on the lower fairings this morning - replacing the inside duct inserts so everything is now nice and tight w/no rattles.
    I can do this work now very easily, having the right tools and fasteners. I even poured some lubricant into the inserts to help mitigate future corrosion. ;)
    They look better on the outside then the inside. My objective was just to repair all cracks and missing pieces with any aesthetic work coming later if desired. The nasty repair on the left lower area was done by someone else. They also removed the slender leg that sticks out but that's hardly noticeable once they are on the bike.
    When I got the bike - the lowers were held on at the bottom front with just a cable tie. One bracket was totally missing and so was ABS on both sides. Now they will have the OEM hairpins securing them.
    I even used a foaming de-greaser to get the grime and grease out of this part.....
    #53
  14. Bazza
    Bazza Member
    Had to use something to hold one of the hairpins further apart....worked like a charm!
    Windscreen done - did two of them!
    Two more screws to go but rain hit again so taking a break now....
    #54
  15. squirrelman
    what kinda treatment dija do to the windsheilds ??
    #55
  16. Bazza
    Bazza Member
    NOVUS PK1-2 Plastic Clean & Shine #1, Fine Scratch Remover #2, Heavy Scratch Remover #3 and Polish Mates Pack | 2 Ounce Bottles
    From Amazon.
    Works great!
    #56
    Looking good!
    #57
    Bazza likes this.
  18. Bazza
    Bazza Member
    #58
  19. Captain 80s
    I have used 2 stickers before and wrapped each one into the split at the right spot and trimmed.
    #59
    Bazza likes this.
  20. Bazza
    Bazza Member
    Good idea - thanks!
    Had trouble getting the 2 halves to line up properly - I'm sure because of my sloppy repairs. But it's better than before. Maybe a good thing to have Bidendum there to help hold them together...lol....
    #60
