VFR complete rebuild
Discussion in '5th Generation 1998-2001' started by OnlyVfr, May 16, 2021.
  1. One Ida 31
    One Ida 31 New Member
    Visalia in the People's Republic of Kalifornia
    [QUOTE You ="OnlyVfr, post: 626076, member: 34453"]Hi,
    Bike is very dirty, did not have time to wash it. Would not show work and effort put into this bike when dirty. I will try to wash it over the weekend, then take proper pictures and upload here:) Thank you for advice on the app, but I don't use smartphones, just old good 6310i :D[/QUOTE]
    #61
  2. One Ida 31
    [yQUOTE="OnlyVfr, post: 626076, member: 34453"]Hi,
    You put a tremendous amount of work into the old girl. It shows! Good job and great documentation; thanks!
    #62
    OnlyVfr likes this.
  3. Repping
    Repping New Member
    Now that ‘looks’ like a job well doen.
    Have to see the end result thought
    #63
    OnlyVfr likes this.
  4. Repping
    Repping New Member
    What backlight LED’s did you use for the instrument panel.
    Cheers
    #64
  5. OnlyVfr
    OnlyVfr New Member
    Ireland
    Hi,
    I bought LEDs from ebay, just checked compatibility and picked no brand ones in blue. However, I never installed LEDs for oil, fi, neutral, high beams because they were too big and did not fit at all:( So back light for the clocks are LEDs, lower part of the dash old bulbs. Probably my mistake when buying leds.
    #65
  6. Repping
    Repping New Member
    Just really keen to find out which ones you used because a lot of mods have bright spots because the leds are to powerful.
    So if you can find which ones that would be coolS
    Cheers
    #66
  7. OnlyVfr
    OnlyVfr New Member
    Ireland
    I have spares at home, will take pictures when I am back home and post here if that helps?
    #67
  8. Repping
    Repping New Member
    Yes please.
    Really hard to find the correct ones that don’t overpower the backlighting.
    #68
    OnlyVfr likes this.
  9. OnlyVfr
    OnlyVfr New Member
    Ireland
    Unfortunately I don't have any of dashboard leds left, just the ones which were supposed to go into controls and did not fit, too fat. I checked my ebay history but it was long time ago when I bought it and I could find nothing. Sorry about that.
    #69
    Repping likes this.
  10. Repping
    Repping New Member
    Hi, cheers for that.
    Are these exactly the same shape as the ones you used for the dash and I assume the plastic colour is also the colour of the light that is being emitted?
    #70
  11. OnlyVfr
    OnlyVfr New Member
    Ireland
    No, the dash board ones are big. I have just noticed, if you zoom in on pictures attached you can see them:)
    #71
    Repping likes this.
  12. raYzerman
    raYzerman Member
    Millgrove, ON
    Perhaps to help you along with your decision..........
    I used Superbright LED's in mine, green for backlighting, amber for turn signal indicators.... these are the larger ones, #194.
    Small ones for the warning lights are #74 in the appropriate colour. Note, do not put an LED in the FI light, it needs to stay incandescent or it will not turn off.
    These are bright enough to be easily seen in daytime.... at night they will seem much brighter and might be a bit much. However, not intending to ride this bike at night....
    #72
    Repping, OnlyVfr and Diving Pete like this.
  13. Repping
    Repping New Member
    Like your mod but , I do need to ride the bike at night time and I need something that does not overpower the instrument panel with light at night.
    Cheers though.
    #73
  14. Repping
    Repping New Member
    Cheers for coming back other wise I would be buying the wrongs ones.
    Cheers
    #74
  15. OnlyVfr
    OnlyVfr New Member
    Ireland
    As promised. Bike was just cleaned with a wet cloth, power washer was not available and I had not time, but did what I could so I could post some pictures.
    #75
    alexey likes this.
  16. OnlyVfr
    OnlyVfr New Member
    Ireland
    #76
    alexey likes this.
  17. OnlyVfr
    OnlyVfr New Member
    Ireland
    I am thinking of:
    1. Clear clutch cover
    2. Mirrors with indicators , blank off old ones.
    3. Changing head light bulbs for something more advanced.
    4. Turbo:D just joking:)
    #77
    alexey likes this.
  18. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    Great work, bike must be brilliant to ride now, just thinking of doing a bar conversion on mine to the hurricane type.
    #78
    OnlyVfr likes this.
  19. OnlyVfr
    OnlyVfr New Member
    Ireland
    Thank you. I only rode it for couple miles to check the speedo vs gps. Seems ok ,but need to test on higher speeds. If you do conversion, please post it on forum:)
    #79
    VFRIRL likes this.
  20. alexey
    alexey New Member
    Ukraine
    interesting is it possible to ask you for a model of adapters for calipers?
    #80
