VFR Top Speed is ????
Discussion in 'General VFR Discussions' started by Wu-Viffer, Jan 12, 2007.
  1. Voided76
    Voided76 New Member
    San Diego, CA
    if candy can N/A tune to 130 mph, you know somethings up ;)
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I have not seen a supercharged Vfr quarter mile. I have Only seen eighth mile runs and those were stupid fast trapping at 115. Anyways I talked to toe cutter about this and it was cured with 100 pound clutch springs. So the engine and driveline is up to the task, it just needed some tweeking.
    Anyways my last quart mile run was 10.8 flat at 128, uncorrected and untuned (so higher numbers are definitely possible). Also I still have not pulled the heads for porting/polishing/milling or bigger cams.
    You guys better get ready to see some ridiculous numbers soon. I should have the rapid bike racing on by mid September and dialed in shortly there after. Once I have a perfect base map, we are going to tune the second map for a decent shot of nitrous :)
    Oh and guys, here is the cumulation of all our efforts:
    http://rapidbike.us/products/2002-2009-vfr800-special-project
  3. Badbilly
    Is this video on Utube?
  4. Gweglez
    Gweglez New Member
    Southampton, United Kingdom
    I've got an indicated 153 UK mph on my 6th Gen, it will do a bit more but that was with the givi rack and E55 Maxia 3 box on! Probably a bit more without them though I remember seeing somewhere that the vfr's are over geared and run out of power before they do top speed. It'll do an indicated 140 in 4th so 5th and 6th are just for cruising really
  5. Badbilly
    Amazing that oot of all the posts on how fast these individual bikes can go, there are only two dudes here with posted timing slips. In the meantime my mach 1 91 though unsupported by any evidence is the mostest fastest mofo (ing) VFR on the planet.
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    10/10 Quality post
  7. sunofwolf
    sunofwolf New Member
    45 teeth would get me maybe a 150-I hit 100+ on the back roads-speedo healer is here-now how does this slilly thing work?
  8. Badbilly
    Any other source will do. Geographic location? Certification? Date? Temp? Time? Rider? Modifications to the bike?
  9. sunofwolf
    :glee::croc::spit::spit::spit::spit::spit::spit::tsk:BB has no bike-never seen a single pic, he does it the old fashion way-he uses other peoples stuff -breaks it then says why did you give me a broken Bike!
  10. Voided76
    Voided76 New Member
    San Diego, CA
    dickhead dickhead
  11. Badbilly
    IMO, those terms only serve to get SOW all excited.
  12. Voided76
    Voided76 New Member
    San Diego, CA
    LOL
    well if I knew it was gonna be That kinda party, I'd have brought my g string and some nair...
  13. Badbilly
    Don't get him started! Next, he will be waxing Brazilian..
  14. Badbilly
    Could you post the data aboot this bike run before you go? After 34 pages of fast bikes it would be really great to see just a little more actual evidence rather than trying to read an analog dial or an LCD screen thet displays type in the area of 10-12 point at well over 100mph.
    TIA
  15. Voided76
    Voided76 New Member
    San Diego, CA
    45 teeth would net you 150 if your bike pulled hard and made power past 10k. Doesnt and wont for you. Youll see about 140 in top gear. 10.75-11 grand. Speedo will say 155-160.. utterly wrong though.
  16. sunofwolf
    Don't let BB get you down 7yrs with a real bike is worth its weight in silver. There just happens to be some real nasty people here sometimes. Just stop posting for a while.
  17. Voided76
    Voided76 New Member
    San Diego, CA
    Practice what you're preaching there dickhead...
  18. Badbilly
    Gold just dropped aboot seven points
    Gold @ 1260
    Silver @ 18
    Platinum @ 1395
    Palladium @ 878
    Making it even more clear that SOW is a tinhorn.
  19. Badbilly
  20. sunofwolf
    BB is into some really strange stuff, must be boring sitting on that Bridge all the time, when people have figured out-they can just go around the Troll and go to another bridge!
