VFR800 ´98 army green project
Discussion in '5th Generation 1998-2001' started by bjorn17, Aug 27, 2014.
  1. hamiltonfighter
    hamiltonfighter New Member
    Aaaaggghhh!!! You beat me to this paint job.
    Did you rattle can it? Is there a clear coat?
    I have been planning to do a similar paint scheme to my sixth gen this winter. I'm wanting to do an olive drab with clear coat. Am also wanting to make the rims orange. Decals would also be stenciled on with white or matching orange paint using a crackle effect. I would also get a orange LED fairing light kit.
    Here's an idea:
  2. Skifreak
    Skifreak New Member
    Washington State
    Sounds like a good plan to me. I seem to have started from the other end.
  3. bjorn17
    bjorn17 New Member
    It does not have a clear coat. I only bought two component NATO RAL6013 matte green acrylic paint from the paint shop and a paint pistol to paint with. It does have an undercoat. I did 2 layers of green, if you do more it will not be as matte looking.
  4. Badbilly
    Good job on fixing the dented tank. Kind of wondered which "Army" green was used.. The bike looks better with the clear windscreen IMO. This breaks up a large monochromatic color mass that was a little overwhelming.
    Good thinking that every paintjob on a bike does not have to be shiney. The color is Olive Drab..
    Some bright orange wheels maybe??
  5. bjorn17
    bjorn17 New Member
    Only a few weeks of riding season left here in Estonia. So won´t do anything else this year. However for the next one I am planning maybe a Power Commander install.
    Since I have a 98 model without the O2 Sensors (I haven´t atleast seen any on the exhaust) then I understand I can use pretty much any PC3 Serial/Usb to PC5 unit that fits a VFR800, correct? And the existance of O2 plugs is not a matter on my case.
    If Power Commander does not use the value of the O2 sensors, then how does it measure the output? It doesn´t? As I udnerstand at the moment it only takes and modifies values for air intake and fuel injection, correct?
    P.S. If anyone would have a PC for VFR800 to sell, then I am your man!
  6. bjorn17
    bjorn17 New Member
    I understood that PC still enables better low RPM response, no?
  7. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Yes it does. Really helps smooth out the low speed operation. IMO anyway.
  8. Allyance
    Allyance Insider
    Germany
    East Bay, California
    The PC III doesn't need or read the O2 sensors, that is why dummy 330 ohm resistors are used to fool the ECU, the PC III provides the correct mapping without the O2 sensors. I was one the first thing I did to smooth out my '03.
