vfr800 cooling fan not coming on
Discussion in 'Mechanics Garage' started by hughc62, Apr 28, 2013.
  1. Diving Pete
    84c is a VERY low temp to come on - my 6th gen its 106c Normal running temps are 78c (on the move) & anything up to 110c in really bad (Stationary) conditions...
  2. raYzerman
    raYzerman Member
    Millgrove, ON
    I believe the coolant display is taken from the coolant temp sensor which may not be the same temperature at the fan switch, but would be closer if the entire system was evenly stabilized at that given moment.... The service manuals don't give a temperature....... however, the thermostat starts to open 80-84C and should be fully open at 95C.... perhaps 84C is a bit low, but maybe better tested a few times to confirm a better average?
  3. Microwavable
    Microwavable New Member
    New Zealand
    Levin, New Zealand
    @raYzerman , @Diving Pete I too was surprised it came on at 84c I was expecting mid 90's tbh. I think @raYzerman has a point, we are leaving on a long trip tomorrow. I will post a pic below. So we should get a good indication of the temp the fan comes on on average.
    looks to be around 1300k's
  4. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    Hello, first time caller here.
    Did anyone ever get to the bottom of this? I have a 2006 with the same problem, no fan.
    Fan comes on when the wire is grounded, just fitted a new genuine radiator switch and nothing. Switch should come on at 100c I left it ticking over up to 107 before I bottled it and switched off.
    Coolant is to the top. Fuse is good. Fans work when manually over-ridden against the metal of the radiator. Temp comes down pretty quickly when I override the switch so I don't think I've got a blocked rad. When driving at normal speeds the temp sits at about 78c which is what I'd expect, espiecially at this time of year. I'm lost as to what to try next? Any ideas?
  5. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    I think there's a chance I've got either a blocked left hand rad, or there's air trapped up in that corner next to the fan switch.
    I'm going to try and flush the rad tomorrow, and then refill and burp the system on the side stand to try and remove any air. I can slacken off the switch a couple of turns too to try and release any air that might be trapped up there. Hopefully it'll help. I'll report back if it works!
  6. Terry Smith
    The fan power is supplied live to the motor, with the connection to earth being through the switch and then the radiator body.
    You have shown the fan to work when jumpered to a ground (the radiator) so there's no supply side issue. I think you're on the right track considering whether the switch is airlocked, but another possibility is the connection between the switch body and radiator, is there a chance it has some threadtape that is causing it to be insulated? A quick continuity check between the switch body and radiator would eliminate that one.
    MrGorsky likes this.
  7. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    So I've had it all apart this morning. Can confirm continuity between the switch body and the rad. It was a brand new Honda one that I fitted so I thought it would be fine. I didn't use any thread sealant or anything. Anyway, took the rad off and gave it a flush. It all looks spanking new in there, but I'd taken it off so I thought I may as well. Put it all back together, filled the system, burped the system, unscrewed the new switch and let a little coolant out to remove any air from that side of the bike and NOTHING.
    After a little head scratching I tool the switch out and did the boiling water test on it..... also nothing. My rand new genuine Honda thermo switch is also duff.
    There's a lesson to be learned here somewhere.......
  8. Terry Smith
    Sounds like good fault finding but boiling water to test won't work as the switch point is at more than 100C and that is as high as boiling water can go. You might try it again in some 50% coolant (boiling point 106C which is just above the switching point) or oil.
  9. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    According to the service manual it should open between 98-102c. It's marked on the side with "100 ON". Anyway, it does stand to science that water can only get to 100c before it's not water any more..... I hadn't really thought of that, but I was hoping I'd get a beep out of my multimeter at some stage. I had the gas on full!
    Are we saying I'm back to square 1? I'm not quite sure what the consequences of putting coolant in my wife's saucepans will be.
  10. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    It's just occured to me, I did test it in the bike. The dash temp said 106c or so, and there was no continuity between the spade connection, and the rad body. That suggests the switch is duff doesn't it? Of course I'm not sure how accurate the dash temp guage is but still.....
  11. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    Well, here's an update of sorts, and I'm going to leave it here. I bought a cheap eBay used genuine part to try out. Also stamped 100 ON on the side. I fitted it and went for a burn and then stoopped in a lay-by to see if the fan would come on. At tick-over the temp crept up past 102c and no fan. I decided I'd leave it to 110c and see what happens. Eventually at 107c the fan kicked in, and then off again at 97.
    So maybe my brand new genuine switch is good, but I switched off before it had a chance to kick in the other day? I dunno. I'm using the dashboard temp display to measure the coolant temp, and I have no idea how accurate that is, and of course the block temp might be a good bit hotter than the top of the rad temp, so there's every chance it's working as intended.
    The fan came on well below the 122c overheat figure stated in the owners mannual, so I think it's probably me just worrying rather than a problem with the cooling system.
    One day if I ever get one of those infared temp gun things I'll test it again, but until then it'll have to wait! Thanks for your help and ideas, very useful.
  12. Terry Smith
    That would gel with my experiences as well; I've occasionally seen the fan activation around 106 when just idling too. You're quite correct that the ECT sensor is on the block where it could be exposed to temps higher than at the radiator.
    I expect the engine speed and hence flow speed of the coolant will play a part here; at higher engine speeds the coolant will circulate through the radiators more quickly so the block and radiator temps would be likely to be closer together.
    Life was a lot simpler in the analogue gauge era. Needle not in the red? Everything's fine. Now we fret about a few degrees. I note that more recent bikes (e.g. my ST1300 and VFR1200) have dispensed with digits and gone to a bar graph format that is less alarming.
  13. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    Reminds me of something I read once, about Jaguar cars deciding to go with "BLUE-NORMAL-RED" temp guages and oil pressure lights instead of calibratred Smiths guages because they had so many people taking their cars back worried about low oil pressure at idle, and blocked rads because the needles would move all over in what was perfectly normal operation, but people panicked thinking their oil pump was duff, ot the car was always about to overheat!
    I wish I still had my FV!
  14. Dannoxyz
    Dannoxyz New Member
    Mesa, AZ
    Good job! Testing fam thermoswitch with boiling water should be very 1st test done (add some salt or coolant to raise boiling point temp). Much, much safer for bike than letting it overheat to see if fan turns on!
    IF you measure power at wire to thermoswitch, then fuse is obviously OK, so don't waste any time on that.
    Note that thermo-sensor that drives dash gauge, is NOT in same location as fan thermoswitch. Best to use infrared thermometer and measure temp of radiator metal near where thermoswitch is mounted to get accurate reading of temperature.
    Reason engine must be operated above 100C is that there's water resulting from combustion and water condenses in crankcase when cooling. This water mixes with oil when engine is initially started and operating temps must be brought up above 100C to boil out this water from oil. Only then can oil properly lubricate engine parts.
  15. MrGorsky
    MrGorsky New Member
    Buckinghamshire
    I've been commuting in and out of London regularly and all is good. With this latest bit of hot weather (34c yesterday) the fan comes on more, but when stood in traffic the bike never gets above 108c and comes down pretty quickly with the fan running.
    It was all a bit misunderstanding probably!
    Terry Smith and Dannoxyz like this.
  16. Dannoxyz
    Dannoxyz New Member
    Mesa, AZ
    Good to get some measurements and confirmation to be sure! :)
